250-500cc rear wheel hits muffler
Discussion in '2 Stroke' started by Rickyme, Aug 8, 2015.
  1. Rickyme Husqvarna
    Sydney Australia
    Terra 650, WR300 both 2013
    Yamaha TTR 600 Belgarda
    Ive got a 2013 WR300 with a pro circuit pipe and muffler, Ive just noticed that it looks like the rear wheel hits it as it has scuff marks on the side. Ive got a Pirelli 110 on but before was running 120 size rear.
    Ive checked Ive got t he muffler on the right side of the mounts, the inside right?It certainly looks like it has to fit that way as the mounts have dishes in them for the rubber bits.
    Any one else have this issue ?
  2. Dirtdame Administrator
    Rock Springs Wy
    11 WR300,13 WR125,18 FE501
    17 Beta Xtrainer
    I had a problem with my 2011, with a Michelin 120 getting tire marks on it, but ended up bending the mounts out slightly. End of problem.
    David Hudson likes this.
  3. Rickyme Husqvarna
    Sydney Australia
    sounds like a reasonable solution cheers
  4. gwynfryn Husqvarna
    2009 wr250
    The muffler goes on the outside of the sub frame.
    David Hudson and shawbagga like this.
  5. juicypips Husqvarna
    gloucestershire
    wr 360. 2002
    Yup muff on the outside, put a spacer in between the mounts and subframe if more clearance is required.
    Comanche87 likes this.
  6. shawbagga Husqvarna
    Eaton, Western Australia
    None
    2018 Gasgas XC250
    yeh what this guy said^
  7. Rickyme Husqvarna
    Sydney Australia
    The outside ? ok mines always been on the inside. The shop put the procircuit on that way when I bought it new ... no bloody wonder it rubbs
    thanks for all your replies
    shawbagga likes this.
  8. sned2502st Husqvarna
    2011 WR250
    Dont try and bend tabs, they are weak as hell to begin with. If you look in here you will find that a lot of people have the tabs eventually crack. Mine did. Didnt fall on it either. If they crack, there are some fixes other than welding because the aluminum is not easy to weld.
  9. Rickyme Husqvarna
    Sydney Australia
    I undid the bolts and repositioned on the outside of the subframe just like it was made for it ...how about that.
    No I havnt bent tabs, thanks for heads up
  10. shawbagga Husqvarna
    None
    2018 Gasgas XC250
    watch ya rear brake line on the PC pipes/stinger of silencer. i melted 2 rear lines(well 2nd one still holding but melted plastic & started on braid) from it touching without me knowing
  11. steadydirt Husqvarna
    Ontario
    2007 2002 wr 250 1994 wxe 250
    There is a little flex in the exhaust system at the joint of the silencer and the expansion chamber. You can put a little spacer inside the subframe with a hoseclamp and keep the silencer off the tire. I run a large hose clamp around the silencer and up through the rear fender under the sidepanel to prevent the mounting tabs from breaking. The tabs are under engineered. And I run spacers on the tabs- limits crash damage...
  12. Rickyme Husqvarna
    Sydney Australia
    I rode yesterday and it seems fine now its on the correct side! Ill check the brake line thanks Straw.
