125-200cc rear wheel spacer question
Discussion in '2 Stroke' started by shawbagga, Oct 3, 2014.
  1. shawbagga Husqvarna
    Eaton, Western Australia
    None
    2018 Gasgas XC250
    um ok this is a bit stupid but I punched out the rear bearings on my 13 wr165(first time ive done bearings:applause:) no probs & am gonna put new ones in tomorrow. have them in freezer, seals picked & chockas full of grease ready to go but I forget which way the central spacer goes in. it has a small bush on one end that looks rusted onto spacer & I cant bloody remember which way it goes(bush at single bearing end of hub or double bearing end as in drive side of hub)? anyone know & does it matter? what does that bush do exactly? thanking yall
  2. juicypips Husqvarna
    gloucestershire
    wr 360. 2002
    Im assuming its not dependent on orientation i would put the bush in the side you plan to drive the axle in from all im thinking is it centralises the spacer so it doesnt drop an make putting axle in a nightmare.
    But Ive been wrong before.
  3. MotoMarc36 Husqvarna
    wisconsin
    2012 CR144, 04 TC450, 04 TC250, CR50
    Many. Too many.
    Juicypips has it fairly correct. Distance spacers often have a collar or something on them to help center the collar. The hub will be narrower on the end that the collar-side of the distance spacer goes towards. Ultimately it really doesn't matter, though. If you get it in backwards, it will still distance the bearings properly and prevent them from being side-loaded.:thumbsup:
    Motosportz likes this.
  4. shawbagga Husqvarna
    None
    2018 Gasgas XC250
    sweet gents thanks for replies as usual. here goes my first attempt at installing bearings:thinking:
  5. johnnyboy Husqvarna
    UK
    WR 125
    TM 250f
    Heat the hub with a hot air gun and they just push in with your fingers, No pounding needed !
    steadydirt likes this.
