250-500cc Rear wheel swap over
Discussion in '2 Stroke' started by shawbagga, Jan 5, 2016.
  1. shawbagga Husqvarna
    Eaton, Western Australia
    None
    2018 Gasgas XC250
    Does the LHS drive rear wheel(610/630) fit the RHS drive bikes if you get the 220mm disc? Width, axles, spacers the same? Cheers
  2. shawbagga Husqvarna
    None
    2018 Gasgas XC250
    Was from a 11 te630.
  3. 2premo Husqvarna
    Northern NV
    Sherco 300, 2002 KTM 380EXC
    look up the part number for the hub only for the 630 and 300
    if they are the same number then yes, might use a different spacer etc.
  4. shawbagga Husqvarna
    None
    2018 Gasgas XC250
    Diffrent hubs(630 is newer style) so not sure on width n spoke/sprocket offset. Search function on here doesn't seem to work too well. Googled it n seems there's a 5mm spacer required for some hubs but not sure which
  5. shawbagga Husqvarna
    None
    2018 Gasgas XC250
    Ok so same part number except the 630 hub has an A in it(assuming that is for black paint?).
    Wr300-800096937
    Te630-8A0096937
    So question remains is the spoke lacing different ie shorter spokes to offset n which way if so is it offset?
    My stock rear wheel isn't in too bad of condition(needs few new spokes) but be nice to have a spare with a sand tyre on n diffrent gearing but if it means gotta relace wheel then no deuce. Want plug n play
  6. rancher1 Husqvarna
    WA
    The hubs are the same pattern but the part number with the A is wider, sorry.
  7. shawbagga Husqvarna
    None
    2018 Gasgas XC250
    Ahh shoot oh well. Thanks rancher :)
