Rear wheel won't turn when I tighten nuts
Discussion in 'Vintage Restoration Projects' started by Ruairi, May 17, 2015.
  1. Ruairi Husqvarna
    Gloucester United Kingdom
    125 cr 1979
    I am obviously missing a spacer somewhere.
    Not entirely sure which one.
    Pulled bike apart 2 years ago. Thought I had everything safely tucked away.
    Has anyone got a full set of spacers for a 1979 125cr rear wheel they can either sell me or at least take a picture of the spacers so I can see what's gone?
    From what I can make out from the parts manual I need either part number 1516725-01 or 1516605-01.
    Thank you for any help.
  2. grouty Auto Lover ...
    South West UK
    78 390WR, 78 390 AMX, 500 Humph
    works 73 CCM 520, another 73 CCM520
    Have you a picture of your swing arm ? The 125's usually had the previous years MX arm. Probably the same as my 78 one.
  3. Bigbill Husqvarna
    '83 250wr
    0 right now
  4. visiteur1948 Husqvarna
    france Europe
    husqvarna only
    rear axle 125 cr 1979 ebay usa 17 $ us !:)
  5. Ruairi Husqvarna
    125 cr 1979
    Heres some pictures of my rear wheel and spacers.
    On the non brake side is a spacer not shown on these pictures
    Is anything else obviously missing?
    When I took the wheel apart I cant recall the spacer with the rubber seal but I bought it because the parts diagram says its part of the assembly?
    Is there a spacer that should be between the seal on the hub and the brake plate. Its doing my head in!!
    Again.........any help most appreciated
  6. Ruairi Husqvarna
    125 cr 1979
    The spacer originally not shown in the post above. So that completes my rear axle with spacers pictures.
  7. juicypips Husqvarna
    gloucestershire
    wr 360. 2002
    Gunna hazard a guess here you do have the spacer tube in the hub between the bearings still there right?
  8. visiteur1948 Husqvarna
    france Europe
    husqvarna only
  9. juicypips Husqvarna
    gloucestershire
    wr 360. 2002
    Yup #25 is the bit im refering too.
  10. Ruairi Husqvarna
    125 cr 1979
    Thanks for your assistance guys.
    Yes the bearing spacer is there.
    This is the parts page I have been using.
    My reckoning its either item 30 (or 40) that's missing??
    I would know for certain if I could see a picture. Jef Bens has both parts at 40 Euro inc postage.
  11. juicypips Husqvarna
    gloucestershire
    wr 360. 2002
    If thats for both do it.
  12. ruwfo Administrator
    NJ
    1985 250XC, 2016 FJ-09
    Are you sure you didn't mix up the brake drum backing plate assembly from another bike, cause
    a there NOT interchangeable on every model.
  13. grouty Auto Lover ...
    South West UK
    Something about that back plate does not look right. I have 78 and 79 plates and they are the same front and rear barring the centre bush and torque arm bush. The webs around the outside of the spindle hole are not on mine.
    When you replace the back plate bush, always renew as a pair (30 & 40) also make sure you get a new rubber sealing ring (#49). Miss that little ring out and your new bushes will have a very short life !
  14. grouty Auto Lover ...
    South West UK
    I'm going to stick my neck out here ..... that is the WRONG back plate !
    I have been down tonight to look at my spare ones. None of them look like that. The centre bush in the plate almost looks like a front one. But the outside of the casting is nothing like a 76-79 one.
  15. Ruairi Husqvarna
    125 cr 1979
    You may well be right Grouty. The attached pictures were taken before I stripped the bike down.
    Funnily enough in an earlier message you mentioned my swingarm and I remember something.
    I have been told my bike is a 79.
    When I went bought the spacer sleeves for the swingarm pivot I fitted them and they were miles too long and the swingarm wouldn't fit on the frame.
    So I got 78 sleeves which were shorter and fitted straight on.
    One of the pics shows the two brake plates together. You can see from the pics these are what came off the bike...............but as you say not necessarily right.
    I am going to order the spacers from Jef Bens and will let you know from there.................or do I eBay and try and find a brake plate???
    My aim is to ride this at the last Dorset meeting in September so S**t or bust I am going to sort it out.
    Thanks for all the help to all you guys.
  16. grouty Auto Lover ...
    South West UK
    Hmm, I may be tempted to do the last Dorset Classic too. If I don't have the CCM going I will take the lights off the 390 Auto and use that.
    I would go and buy a brake plate off ebay. If you can, buy a fromt one. There are usually less abused. When you are ordering from Jef get a complete new set of bushes. Press out the steel location sleeve and fit your new two piece bush. Press out the steel centre bush and fit the 2 piece rear one.
    The frame does make it look like a 79, as the rear frame loop is different to the normal ML one.
  17. Ruairi Husqvarna
    125 cr 1979
    OK guys. I feel I am almost at the top of this small hill. I now have the CORRECT backing plate etc. Well spotted Grouty .....thank you.
    Before I go and stick it all together please can you tell me if the spacer is meant to go into the brass bush?
    It would appear to be a "small tap with a hammer fit" rather than just a slide in.....Is this correct before I cock it all up and pay Jef Bens for more parts!!!
    I thank you once again.
  18. grouty Auto Lover ...
    South West UK
    This is common with these bushes. It is all down to the tolerances of the hole in the back plate and the o.d. of the bushes. I usually find I need to apply some T-Cut or Brasso to the sleeve to use as a very fine lapping paste. The sleeve needs to be a free rotating fit. make sure you have ordered a new rubber sealing ring for the outside of the back plate (square section one). Otherwise you will be doing it all over again VERY soon.
    Will it be running for the next Dorset meet in two weeks ?
  19. Ruairi Husqvarna
    125 cr 1979
    Thanks for your help once again. Much appreciated. I owe you a pint or two!!
    Yes I have a new seal so hopefully it will last a bit.
    No I will not be at Dorset. Meant to be moving house but have no firm date so there are a few things on hold.
    Hope to be doing their one in September and the Husky WILL be making an appearance!!
