250-500cc Reassembling WR 360 motor....
Discussion in '2 Stroke' started by kerlinger, Feb 11, 2013.
  1. kerlinger Husqvarna
    Peachtree City
    2001 WR 360
    BMW R11GS, TTR 125, TTR 125
    I"ll be reassembling my WR 360 upper soon; i sent lower out to have crank removed, rebuilt and reassembled. Just curious if i should be aware of any helping hints for assembling upper? Any trick for the piston wrist pin clips?
    This is my first 2 stroke motor since late 70's w/a couple RD 350's.
    I"ve been w/o Husky since early Dec, looking forward to having it running again! The weather is almost perfect here in GA!
  2. uranys Husqvarna
    Pittsburgh, Pa
    96 xr600r
    I haven't dug into mine yet, so i can't really help except to suggest keeping the manual handy, taking your time and double checking everything.
    Looking at the wrist pin clips that came with the oem kit, I don't think they will be too hard to get in. I've been able to get the clips that come with je pistons in by just pushing with my thumb and they are thicker. Just get one end in the groove and gently but firmly work it into place.
    I would like to know who you had rebuild your crank? Did they use oem parts? How much did it cost?
  3. R_Little Husqvarna
    NJ
    google "Mr. Crankshaft" Vince is his name and he is in Kentucky I think.
    Good work quick turnaround.
  4. kerlinger Husqvarna
    Peachtree City
    2001 WR 360
    bought OEM Husky rebuild kit, $350+, didn't realize it included new rod w/crank bearing, also came with piston bearing; had local guy in GA reassemble, $60 charge.
  5. pollolittle Husqvarna
    Tn
    Where did you get that?
  6. kerlinger Husqvarna
    Peachtree City
    2001 WR 360
  7. pollolittle Husqvarna
    Tn
    Where did you get the OEM Husky rebuild kit from?
  8. lankydoug Husqvarna
    MO
    WR
    TM 300en
    +1 on Mr. Crankshaft. Vince is old school and uses the best quality parts available. (No Chinese crap) I used him to repair a blown up Hot Rods crank in a Yamaha and the total turn around time was 3 working days. Mailed it on Thursday and had it back on Monday.
  9. MotoMarc36 Husqvarna
    wisconsin
    2012 CR144, 04 TC450, 04 TC250, CR50
    Many. Too many.
    Open end of wristpin clip should always be at 12:00 or 6:00.
  10. kerlinger Husqvarna
    Peachtree City
    2001 WR 360
    all parts purchased either from Halls in IL or my local Husky dealer (for now) Atlanta BMW Husky Duc
  11. coca2113 Husqvarna
    Blanding UT
    2000 wr 360
    i am new to husqvarna and i am also rebuilding a 2000 wr 360 top end. I did not get a manual when i bought my bike any suggestions on where to buy one?
  12. kerlinger Husqvarna
    Peachtree City
    2001 WR 360
    update on my 360 Husky! It's been slow going with this rebuild project as i have a crazy work travel schedule but i was targeting this Sat as fire up date, but made such good progress Mon & last nite that i was able to try start up last nite; and wouldn't you know it the SOB fired up within 4-5 kicks! The compression is MUCH higher when kicking it, and when running it even sounds different, exhaust note was sharper/crisper...even my 12 year daughter noticed it....doing run in according to Husky manual, so cool thing is the next two times went to kick it over it started on 1st or 2nd kick! i'm sure i still need to fine tune final jetting on the PWK i bought last fall, but i'm very pleased... i've got a small leak on the clutch gasket and am leaking some gear lube, i'll try tightening bolts, but probably will need to replace gasket. overall at this early point very happy with my low grade mechanic abilities!! but with this big time compression improvement i guess i really did have a 'tired' engine....well fresh now & cost me $ 1k, including upgraded fork/shock springs so my handling issues should be solved as well....Thanks to the guys on Husky Cafe who assisted me with suggestions and comments......i'm heading out for longer run tonight and then hopefully trails Sat a.m.....can't wait!!
    2premo and Motosportz like this.
  13. kerlinger Husqvarna
    Peachtree City
    2001 WR 360
    Halls Cycles has parts manual on website, maybe operators manual too?
  14. coca2113 Husqvarna
    Blanding UT
    2000 wr 360
    I called halls and they dont have one. I Guess i am just looking for torque values on the cylinder and head.
  15. Motosportz CH Sponsor
    Good point, i have never done that. :o
  16. kerlinger Husqvarna
    Peachtree City
    2001 WR 360
    pm me your email i might have files i could send you
  17. coca2113 Husqvarna
    Blanding UT
    2000 wr 360
    Thanks so much for your help. coltonhunt_56@msn.com
