Rebound ? Hard, soft clarification ....
Discussion in 'Common Items on Husqvarnas: Tires/tubes/grips/etc' started by DougW, Feb 18, 2013.
  1. DougW Husqvarna
    Santa Clarita, CA
    So I find myself a bit confused about setting rebound. Does the "hard" adjustment setting = a faster rebound?
    Thanks
  2. Motosportz CH Sponsor
    hard / more / clockwise / +
    means it returns slower.
  3. BarberPole Husqvarna
    Above Boone, NC
    2008 TE610
    XT225
    Thanks for answering.
    There is still a LOT of confusion about Rebound and Compression damping on many forums by itself..
    ......not to mention how poorly transcribed the Husky manuals are.
  4. Xcuvator Husqvarna
    Scholls Oregon
    yes
    If you just think of the adjusting screws as little valves (because they are). As you open them (counter clock wise), more oil is bypassed around your shim stacks and allows the shock/fork to move more freely. And conversely...
    Connor likes this.
  5. Motosportz CH Sponsor
    No problem.
    Note your current clicker settings and then turn one at a time all the way in and bounce up and down on it, then turn it all the way out and bounce on it and you should feel the difference and what it is doing.
  6. gillies Husqvarna
    Phoenix, AZ
    '11 TE449
    '09 R1200GSA
    There is a limit to what they'll do, however. Clickers fine tune a properly sprung and valved suspension.
  7. nonamerider Husqvarna
    Oklahoma
    all good info. what bike. generally husky valves light on reb. i have gone stiffer with reb 9/ 10 out with stock settings. if you get susp re done make sure they change reb stack.
