250-500cc Reed Valve Problems?? Wr300
Discussion in '2 Stroke' started by Schony, Jul 30, 2010.
  1. Schony Husqvarna
    Fort Collins
    I am really close to getting a new 09 WR300 and have heard that there is a problem with the stamping on the reed valve that could cause a air leak and lock up the engine? Anyone know anything on this? Is it mostly hype or is it something I should have a look at before hitting the trails?
  2. PC. Husqvarna
    Beaverton, OR
    CR165 & CR144
    KTM500
    Its neither confirmed nor unconfirmed and I've only seen one report of it (on TT), but there is a p/n stamping right on the mating surface of the reed cage and it could be an issue if the bolts aren't all evenly tightened..... I guess :excuseme:
    I went ahead and used gaskets on both sides of the cage for piece of mind.
  3. rasputin Husqvarna
    Bavaria
    never heard of that.
    r
  4. Schony Husqvarna
    Fort Collins
    cool, well if this goes threw i will probably do that when I get time. I remember reading somewhere about things you should do before you ride your new machine... I'll try and find it so I have an Idea where to start. This will be my first ever "new" bike!! :D :thumbsup:
  5. MOTORHEAD Husqvarna
    Mount Vernon, Indiana
    2014 YAMAHA YZ250
    Tell the dealer you want a gasket installed before you buy it, or no deal. :excuseme:
