125-200cc rekluse in a 150
Discussion in '2 Stroke' started by Yellowfin, May 12, 2015.
  1. Yellowfin Husqvarna
    Ocean City, NJ
    '13 WR144
    kdx220 (sold)
    Thinking about getting a rekluse for my 150 but worry about ability to loft front end.
    Anyone here run a rekluse and have a review?
  2. NCSteve Husqvarna
    Appalachia
    12 WR300 13 WR165
    02 XR250R 00 XR100R
    Just posted some in ray_ray's Rekluse thread too. My 300 came with a EXP 2.0 installed which is the first auto clutch I've used. Clutch pull was horrendous, so had to start adapting right away. Now I love it and hardly pull the clutch at all anymore. But that's with a 300, lofting the front end is not an issue. Not sure how a 150 would act. The z-start pro is supposed to have normal clutch action and someone else posted recently it was still available for IT Huskys. May be a better choice for a small-bore. For a strong 250, 300 and up I would think the EXP 2/3.0 works great. Just adjust carefully and gear accordingly and forget about the clutch lever. The no stall feature is almost worth the cost alone.
    During the thaw I swapped back and forth through icy section and ended up going off the very steep low side, backwards! A sapling on the edge got tangled in the handlebars and I hung off of it with the rear pointed straight down. The front tire was just over the edge of the trail, the bike was still running and in 3rd gear. I was so out of shape and tangled up I could barely move. It was all I could do to get a foot on and downshift to 2nd, then roll a little throttle on. The bike easily pulled us up and out of a really bad spot and I didn't use any clutch at all. Was worth every penny that day :cheers:
    edit Gotta say though with the stock carb the general setup didn't work anywhere near as well. Now with a Lectron, Rekluse on a big bore 2t really is a game changer for me. I live in the mountains, lots of steep up and down, but at @160 lbs I'm still able to run taller gears. With 13/46 I still hardly use 1st, just for tight u-turns and if I need to dig a trench :) Biggest difference to me is it builds speed off the bottom and through the mid range noticeably faster, basically goes faster faster :thumbsup: The Lectron helps smooth it all out and make it manageable.
    One trick with the EXP 2 is to keep the revs up so the clutch pull is easier. I use the old mx tactic of playing the brakes against the throttle into and through turns, then I can clutch it easier if I want to, which I like.
    Also practice and like letting the Rekluse do all the work through turns which can be super smooth and low energy output.
  3. Chef Husqvarna
    Ontario, Canada
    08 Cr165, 09 Wr165
    01 Husaberg FE650, 07 BMW 650 Dakar
    I have a rekluse in both a wr144 and a cr125. More often, with the light bike, I bounce the front. I have no clutch lever as I use a lhrb. I never was a clutch and loft guy. Bounce and throttle works for me.
    NCSteve likes this.
  4. NCSteve Husqvarna
    Appalachia
    12 WR300 13 WR165
    02 XR250R 00 XR100R
    Which Rekluse please?
  5. Chef Husqvarna
    Ontario, Canada
    08 Cr165, 09 Wr165
    Expanding plate. Exp
  6. Picklito Husqvarna
    Washington
    430, 430, 430, ,400, 175
    KTM250xc, KTM500mx, KTM440exc
    Are we talking about a Rekluse for the Italian 125/144 motor? Can we have a part number, please?
  7. Picklito Husqvarna
    Washington
    RMS-6051?
  8. NCSteve Husqvarna
    Appalachia
    12 WR300 13 WR165
    02 XR250R 00 XR100R
    I would guess that's the one, only one available it seems. I wonder why the diff in model years for 125 & 150?
    I don't remember the thread, but do remember it was recent and poster said they had to call to get a z-start pro version. I'm pretty sure it was for a wr300. I'm planning to call them at some point soon and ask about the diff btwn EXP2 and 3 and whether it's worth it to upgrade.
  9. Picklito Husqvarna
    Washington
    Well... DARN IT!! Woulda had one long ago if I knew they were making one for the small bore Italian motor. Last I looked, it wasn't there and I was bummed. As for the year differences, I'd be pretty sure it's just because Husky kept changing whether they listed the bike as a 144 or 150, and whether you actually got a 125 with a 144 in a box as I did with my 2012.
  10. Picklito Husqvarna
    Washington
    Ordered it!
  11. NCSteve Husqvarna
    Appalachia
    12 WR300 13 WR165
    02 XR250R 00 XR100R
    Will be interested in how you like it. I'm still planning to build a 165 next winter and was wondering what I'd do for a clutch.
  12. Picklito Husqvarna
    Washington
    There will be a ride report. I've had a Z-Start Pro in a KTM 200, 380, and TE450. Currently have an EXP Core in a KTM 300.
