Rekluse in older bikes
Discussion in 'Vintage/Left Kickers' started by Submit, Nov 30, 2015.
  1. Submit Husqvarna
    Bradford, Ontario
    2012 CR125, 86 430 AUTO
    Just out of curiosity has anyone put a Rekluse clutch in their older bike's? There's an 87 400 with 86 plastics for sale in my area ( guy is asking far too much in my opion). Anyway I'm seriously considering purchasing this bike at a lower price then he's offering and was wondering if it would be possible.
  2. Joe Chod Husqvarna
    upstate NY
    IF they made it it would not clear the primary / clutch cover. And you could not use a spacer then the shift and kicker would not mate.
  3. Submit Husqvarna
    Bradford, Ontario
    So it won't work at all is what you're saying?
  4. everfree Husqvarna
    Bend, Oregon
    86 430AE (2), 88 430AE, 87 430WR (2)
    87 250 XC, 87 430 CR, '17 GG 300
    I looked into an Auto Clutch for my 430s. EFM also makes an auto clutch and it's cheaper than the Rekluse.
    I emailed Garry the owner. Nice guy, he will make an auto clutch for anything. He said his clutch needs at least 1/2 inch (13mm) of extra space.
    http://www.efmautoclutch.com/dirt.shtml
    Joe is right, it would need a spacer.
    Since the older Huskys have left-hand kicker and no separate clutch cover, an auto clutch wouldn't work.
    Here's a pic of the EFM auto clutch installed with spacer on a Honda or something...
  5. grouty Auto Lover ...
    South West UK
    78 390WR, 78 390 AMX, 500 Humph
    works 73 CCM 520, another 73 CCM520
    What about the later covers that had a separate removable clutch cover ? You could make a CNC machined spacer to fit. The gear lever can be modified.
  6. everfree Husqvarna
    Bend, Oregon
    Later years maybe. As long as the kickstarter is not part of the clutch cover. "check your application" as they say.
    Easier to modify the gear lever but not the kicker. And the coolant impeller. Not realistic on the left-kicker Swedish made, that I could see.
  7. Autopilot Husqvarna
    Yorkshire, UK
    Automatics 250/420/500/430LC, 510TE
    GasGas 300
    I had EFM make me an Auto clutch for my '86 510 about 4 years ago. It was explained to me about the spacer being needed so I used one of the later clutch covers from a 1997 610. As it turned out it fitted perfectly without the spacer so I can only assume there is a lot more clearance in the older bikes than there is in a modern one.
    I ran it for a season then went back to the conventional clutch, it's not bad but it's not as good as the Rekluse in my GasGas 300. So yes its possible to do and if anyone is interested I might be willing to part with the EFM Auto clutch, it cost me in the region of about $650 to have made. Thinking about it, it would probably work better in the 2 stroke 430 than it does on the 4 stroke.
  8. grouty Auto Lover ...
    South West UK
  9. justintendo klotz super techniplate junkie
    mercer, pa/northwest pa
    99 kawasaki zrx 1100
