Rekluse Install TE450
Discussion in '4 Stroke' started by denmcken, Feb 4, 2010.
  1. denmcken Husqvarna
    IL
    Hi All,
    I'm installing a Rekluse clutch into my 05 TE450. The directions seem pretty straight forward... anything to be aware of or shortcuts to ease the process? I want to set the bike up for a slower single track rider. Is the set-up recommended by the instructions ok?
    Lastly, there seems to be a fair number of posts floating around the internet concerning slave issues. Can you use the clutch normally with the engine running? Only with throttle? Never again?
    Thanks,
    Dennis
  2. life_in_sepia Husqvarna
    Hi Dennis. I have an 06 510. I've used the rekluse since almost new, without hiccup. The instructions are pretty good. You'll get a feel for the two variables, the weight of the balls and the opposite pressure of the springs, to allow you to set it up for the right rpm engage and rate of engagement. It may take a few tries. I needed more of the heavier balls to get the engagement set at a lower rpm, which I liked (sounds like you might too). Beyond that, my only suggestions are (a) make sure you wear-in and adjust the clutch, which will likely take a few adjustments, before you take the bike out in the boonies (ask me how I know), and (b) make sure you have the cover screws loc-tited in once adjusted, or they will back out (ask me how I know). With my rekluse settled, it has given me about 4k miles without need for one adjustment. I took off the clutch, so no slave issues for me, and I like the LHRB setup very much. I hope that helpful to you. Enjoy. Ed
  3. denmcken Husqvarna
    IL
    Thanks for suggestions Ed. Glad to hear you're happy with yours. I wasn't sure if this was right for my level/style... etc. Sounds like our styles are similar.... and your remarks are very encouraging!
    Thanks again,
    Dennis
  4. ghte Husqvarna
    Bright, Victoria Australia
    Hi denmcken, If you undertake this process how about a few instalation shots or video. It would be welcomed by many I am sure.
  5. denmcken Husqvarna
    IL
    I can do that.... I will probably do the install next weekend. I will post up with pics....
  6. Xcuvator Husqvarna
    Scholls Oregon
    yes
    The instructions are very good. You should be able to breeze through. If there is a question, the guy on the other end at tech support is the engineer who designed it.
    Did you get the Pro model?
  7. denmcken Husqvarna
    IL
    No pro model for the 05 TE450... I wish they did, I would've ordered it.
  8. OM48 Husqvarna
    S.W. Pa.
    I put a PRO on my 06 TC510 and like it except for the bike stalling sometime in a quick on-off-on throttle situation. (Thank the previous owner for the e-start). If I put a tack on and adjust the fuel screw before just about every ride it helps but doesn't completely cure it. Any ideas out there? I have the JD kit. Sorry about the hijack but you might be asking the same thing later.
  9. denmcken Husqvarna
    IL
    The Rekluse is in.... should I do the write up with pics here or start another thread?
