Rekluse Pro autoclutch te250
Discussion in '4 Stroke' started by sidquick, Sep 30, 2009.
  1. sidquick Husqvarna
    Hey everyone was just wondering if anyone has fitted a rekluse pro auto clutch to a 2009 te250 I'm real tempted to fit one because not many people use them down here, give me the edge hehe and dont tell no one. But there site said they wont fit:banghead: then the dealer said he would get one in for 1350:censored: in my workshop I'v got a large mill a medium lath and a small surface grider so I do all my own work and make most of my parts, I can get one in from the us for about 700 max I think. The reason for going the Rekluse is that you can tune it to come in just above idle. I got quoted 550 us for a afm auto clutch with manual over ride but there set to come in at 3000 rpm which I think is a bit high espicial when you try and blip the throttle to get a bit of engine braking on long down hils.
    any ideas?
    cheers
    sid
  2. socaltrailrider Husqvarna
    Tustin, CA
    I just installed an EFM in my 04 TE 250. You can adjust it to engage just off throttle. It took me a couple of different adjustments to get it just right, but it works. Garry at EFM is very helpful in getting it set up. It does have manual override, but it's not full manual like the Rekluse Pro and the clutch feel is real soft. I only will use the lever to either get the rpm's back up if climbing a steep hill or to launch the front wheel over something, and it works good for that.
  3. sidquick Husqvarna
    kool so can i use the clutch for proper race starts?
    cheers
