FE/FC Remap feels wrong
Discussion in '4st' started by lodom, Sep 2, 2015.
  1. lodom Husqvarna
    2015 FE 350s
    2012 Suzuki DL650
    Hello all! New here, hope you don't mind if I just dive right in.
    Took my new 350s with 7 hrs on it to my LBS to have them "flash" it. It felt like a vast improve on the parking lot ride. I got home and the first thing I did was install the BDSB exhaust cap. Now it's surging and popping terribly. My understanding was the EU map was richer and designed for a more open exhaust.
    Would a re-flash measure and fix the problem? I'm just looking for a little more off-the-bottom pull for trail riding. (I've change to 13/48 and that helped a lot)
    Haven't been able to reach the service tech yet.
  2. lodom Husqvarna
    2015 FE 350s
    2012 Suzuki DL650
    Service tech had another go at it and it's all good now. Lots of bottom, snappy throttle and almost zero popping.
  3. wilmar13 Husqvarna
    Los Angeles, CA
    FE350S
    1190R
    I am about two steps behind you... just got my ECU back with Euro FE map on the table and BDSB cap in a box. I installed springs front and rear and 13-49 sprockets installed last night. woot woot.
    One thing I learned about the Euro FE map is that it is semi closed loop* and the ECU is more advanced than I thought. It uses the MAP and IAT sensors in lieu of O2 sensor feedback to make global changes to fueling during an idle reset so you are supposed to let it idle for 5min and then blip the throttle to the stop for any change you make. Try that to see if it self corrects. Sounds like it pulled a bunch of fuel to match the restrictive stock exhaust and now it is still running in that trim even though you changed the endcap.
    *- it is not going to be as accurate as closed loop with wideband O2 sensors, or probably even standard ones like your car, but it is better than nothing.
  4. reveille Husqvarna
    Northern Illinois
    2014 FE501
    2015 300 XC W
    I thought I read somewhere that the S models ECU's were unlockable and a add on tuner was the only choice or replace the ECU with the non S. Maybe I mis read that?
  5. wilmar13 Husqvarna
    Los Angeles, CA
    FE350S
    1190R
    Believe only half of what you see, and none of what you read on Cafe Husky. ;)
  6. lodom Husqvarna
    2015 FE 350s
    2012 Suzuki DL650
    Just did the LBL 200 and the bike was perfect! Throttle blips over mud holes and logs were child's play. I can't believe how much better this bike handles on rough single track than the old DRZ.
    Yeah the tech told me up front that he doubted he could change the mapping. He said Husky told him it would just reset back to stock. He was able to plug in the FE map, so far so good.
