Removing a fastener
Discussion in 'General (Main)' started by glangston, Aug 25, 2009.
  1. glangston Husqvarna
    2012 Husqvarna TE 310
    2012 BETA 350 RS
    A fastener for the plastic over the muffler has decided it doesn't want to be removed. It turns but doesn't move...in or out. Can't get a grip on it with pliers as it is sucked right up the to plastic.
  2. BlueHusky144 Husqvarna
    Staunton, IL
    Is it a fastener that screws in to the subframe? If it is you probably have a insert that is turning along with the screw? Try applying pressure with 1 or 2 screwdrivers behind the plastic or even behind the washer/spacer itself while trying to unscrew the bolt.
    This is a real pain if the problem is what I think it is. Good Luck!!
  3. Motosportz CH Sponsor
    Or if thats the case try an air impact wrench to snap it out.
  4. glangston Husqvarna
    2012 BETA 350 RS
    Went to George's. he's got a tool that removes the inserts...hydraulic ($500). Correct... the impact worked to remove the fastener. Glad I took the trip down to Uptite,....like hitting the EASY button.;)
