Removing swingarm needle bearings
Discussion in 'Vintage/Left Kickers' started by Rossik, Jun 6, 2013.
  1. Rossik Husqvarna
    West London
    1985 Husqvarna 500AE
    I am about to replace my swingarm bearings but am stuck trying to rem ove the old ones - is there a trick that doesn't involve too much brute force?
    Typically I have just got my frame and swingarm back from the paint shop before realised the needle bearings are still in there, and no doubt stuck from years of rust and abuse........
  2. adam6402 Husqvarna
    Tulsa, OK
    None
    I have a limited tool supply, I used a long 3/8's socket drive and a perfect fit spark plug socket to drive against the bearing via large mallet. I also applied lots of PB blaster before hand and heat. Honestly, should have just found someone with a press, but I'm stuborn!
    Rossik likes this.
  3. Old Geezer Husqvarna
    Washington state, central desert country
    1983 XC500, 1985 CR500
    1973 Yamaha 360 MX, Harley FatBoy
    That's basically what I did when rebuilding my bro's 500CR. "A little heat" is mandatory as far as I'm concerned. Just a simple warming up with a propane torch, and those bearings will drive right out of there. Sure wish I had a press to do it right, but not really necessary.
    You should, however, try to press them back in vs. driving them so as to guard against getting them cock-eyed. I simply pressed the new ones in using the jaws of my shop vice. That enables you to keep things squared and lined up.
    Rossik likes this.
  4. Rossik Husqvarna
    West London
    OK, great, thanks guys - I'll take it to a shop I think as I don't have access to a prss and given that the swingarm is freshly painted, I'd be so bummed if I slipped while swinging the mallet and chipped it...........thanks again.
    So next question, is there anyone out there who can recommend a decent bike workshop in south east UK who has some vintage experience?
  5. husqyman Husqvarna
    S.E Kent UK
    1988 XC430, 1987 250WR.
    Triumph Tiger 955i
    Roy Simmons engineering of Brook near Ashford Kent 01233 813385 for machine shop and engine building.
    He is an old school style engineer/machinist with a workshop on the side of his house, re bored a yz250 barrel one day turn around £34.00 (3years back) last year fitted a new con rod kit to a KDX 200 while I waited and true'd to within 1.5thou run out (kawasaki usually to 4 from factory) £30.00 30mins to do the job. He can be difficult to get hold of as he semi retired and still works part time somwhere else. But he is good.
    Rossik likes this.
  6. steadydirt Husqvarna
    Ontario
    2007 2002 wr 250 1994 wxe 250
    Guys!- you all have a press. It's called a vise. The sockets mentioned earlier work fine in a vise- no beating on it. Good control. Bunch of roughnecks!
    darren7878 likes this.
  7. auto Husqvarna
    NJ,USA
    too many
    When you use a vise you need a extra set of hands!
  8. GaryM Husqvarna
    Austin, Tx
    1981 430cr second 430 CR 500cr
    1981 490 Maico
    Just go down and pick up a threaded rod. Match up a stack of hardened washers with matching inside ID. And slowly turn your nut and
    you now have a pressed out the bearing. Just look at the motion pro tool for the same idea.
    adam6402 likes this.
  9. adam6402 Husqvarna
    Tulsa, OK
    None
    I'm a goon without a vise either. Gary, good and very simple idea, the kind of solutions I like!
  10. suprize Husqvarna
    Bendigo, Australia
    ktm 300
    Socket in the vise always works well, lots of WD 40! Get a can of touch up paint!!!
  11. dingodog Husqvarna
    The Garden State, Au
    '73 CR125, '82 WR250,
    XC150
    Are these 'blind' bearings? I don't reckon my have come out since the factory.
  12. Bigbill Husqvarna
    '83 250wr
    0 right now
    You can use a large c clamp like a vise too with the sockets.
  13. justintendo klotz super techniplate junkie
    mercer, pa/northwest pa
    99 kawasaki zrx 1100
    sometimes i use my balljoint press, a vice, or a large c-clamp. several ways to go about it..
  14. Bigbill Husqvarna
    '83 250wr
    0 right now
    A threaded rod can be used through both holes and use a flat washer with a nut on one side to pull the bearing out. You need another flat washer the diameter of the bearing.
    Time to think and come up with a way of doing anything. I made all my own tool. I welded a metric nut on a pipe with a nut on the other end to turn with w ratchet, to remove the fork tubes in a 85 250cr Honda to do the fork seals. My point is we get the job done. Wether in our garage or basement.
  15. dingodog Husqvarna
    XC150
    Just wondering if they are up against anything in there, internal flange, 'blind' hole or are both the bearings up against themselves, come out either way? Thanks
  16. Houredout401 Husqvarna
    New England
    '77 CR250 '78WR250
    '76MR250 '83IT250 '84 IT490 '69CT70
    As long as there has not been any damage to the edges, they press out either way. Should not take too much force - if it does make sure you don't have too big of a socket and that it is aligned properly. The threaded rod (i.e. motion pro tool style) works best, but I've used the vice set up with no issues as well. The motion pro tool is very nice for re-install as the precision machined drivers fit perfectly inside the bearing to hold needles in and keep everything lined up.
  17. silverstreakNZ Husqvarna
    Christchurch nz
    82cr500,76gp360,90wr250,81 420AXC
    74 tm400 , 02 gasgas ec 300
    Reciprocating saw . Or hack saw
  18. Eric The Leg Husqvarna
    Currently Tacoma, WA
    1986 WR400, 1985 WRX400, 1979 WR250
    83 Kawasaki KZ 440
    If you take threaded stock (1/4 inch/6mm or similar), long enough to run the full width of the swingarm, and use a stack (stack for rigidity) of washers and a nut on each end, you can press the bearings from the outside in. Just make sure your washer is wide enough to solidly span the bearing, but small enough to fit through the arm end (at-least on one end). The same setup can work to push them out, as well as back in. If you're reefing hard on the nuts at all, put some bracing between the legs of the swingarm, but hopefully with some heat and things soaked up pretty well you don't have to go there. NO impact wrenches when using this approach. No saws either.
  19. Eric The Leg Husqvarna
    83 Kawasaki KZ 440
    Why did we all get suckered into posting on a thread that originated in 2013?
  20. Houredout401 Husqvarna
    New England
    '77 CR250 '78WR250
    Ha! I thought the same thing, but looks like someone is tagging on to an old thread.
