250-500cc Repack WR250-06 Silencer
Discussion in '2 Stroke' started by affeee, Oct 6, 2013.
  1. affeee Husqvarna
    wr 250 - 06
    Hi,
    I have just disassembled the silencer on my WR250-06 (which was quite easy with the help of two cars and their pulleys :) ).
    My question: There is some kind of Steel Wool wrapped around the inner pipe? Do I need this? Can I re-use it?
    Thanks!
  2. Bill502 Husqvarna
    Upstate NY
    2007 WR167 1978 CR250 1938 sw maus
    1970 Triumph T100C 1973 Honda TL125
    Are you sure its not fiberglass?
  3. johnnyboy Husqvarna
    UK
    WR 125
    TM 250f
    Never seen steel wool on a 2 stroke silencer before but plenty on 4 strokes
    You do not need it and at least if you remove it you can clean the perforated core throughly before putting it all back together.
  4. affeee Husqvarna
    wr 250 - 06
    Thanks,
    I guess its fiberglass
    I removed it all, and cleaned the perforated core with brake cleaner and a steel brush.
    So, I will just roll on the new silencer packing "tight enough", and just skip the fiberglass-stuff.
  5. johnnyboy Husqvarna
    UK
    WR 125
    TM 250f
    Looks steel to me !
    Easy way to find out and thats to set it alight :eek: if it burns its steel .
    Be aware it can and will really burn so just throw it as I do not want to be held resposable for you burning your house down :D
  6. affeee Husqvarna
    wr 250 - 06
    Ok, will try that :cheers:
    What is the reason for having both the steel wool AND silencer packing?
    I guess the flame protection is out of the question if it burns...
  7. Bill502 Husqvarna
    Upstate NY
    While you have it apart you might want to clean cone on the output end if its still in there.
  8. shawbagga Husqvarna
    Eaton, Western Australia
    None
    2018 Gasgas XC250
    yeh its steel wool from the factory, my 300 was the same
  9. K5PL5 Husqvarna
    Palmyra, PA
    2012 WR300
    Haha I robbed the packing out of my stock WR pipe and "fabricated" a core out of an old spray paint can and then safety wired the packing around it and stuffed it in my girlfriend's Yamaha RT180. I could smell the paint burning off the steel for a while when she rode it. Yuck smelly haha.
