TE/TC Repacking silencer
Discussion in '2st' started by HS507, Feb 7, 2017.
  1. HS507 Husqvarna
    NE Ohio
    Te 300
    Yz450,crf150r,crf100f,crf50f
    Do you guys use the cheap fmf repacking or the oem rockwool? 30hr or 60hr changes?
  2. shawbagga Husqvarna
    Eaton, Western Australia
    None
    2018 Gasgas XC250
    Cheap matt stuff every top end(50-100 hours bike dependent). Steel wool around core first
  3. HS507 Husqvarna
    NE Ohio
    Te 300
    Flat Steel wool material first wrap? Im kinda confused where i find that at? Ok, so, your saying one wrap wool then cheap white stuff on top?
  4. shawbagga Husqvarna
    None
    2018 Gasgas XC250
    Yeh the proper steel wool shit(they are small pads that u can unwrap) not the stainless scourer things. Yep wrap them over core first covering it all(probably use 6-8 of em) then tightish wrap of Matt packin, use maskin tape to keep in place while puttin can back on
  5. shawbagga Husqvarna
    None
    2018 Gasgas XC250
    Get em at supermarket where scourers, dish washin crap is
  6. HS507 Husqvarna
    NE Ohio
    Te 300
    Ok, will look into it
  7. Hurky Husqvarna
    Spain
    ex: WR300 2010
    Honda CR500AFX + Beta RR300
    Do you mean this stainless kitchen wool ?
    Because I would think that the normal steel wool would not last very long because of the moisture that will transform it into rusty dust in no time :D
    I wasn't really using this steelwool before, what are the benefits of it ?
    Regards.
    PS. I'm using normal white silencer wool and change it about every year or so, Now I should change it again because it started to make some more noise...
  8. shawbagga Husqvarna
    None
    2018 Gasgas XC250
    Nah not them they're the scourer type that would rust up in no time! Steel wool pads. C if I cn find a pic. As long as u rnt puttin the hose down yor exhaust wen washin no probs with rust. Bn doin em this way for years after member Ausky showed me. If u in a dry climate could jus use steel wool for entire packin but take ages to pack it with individual pads!
  9. shawbagga Husqvarna
    None
    2018 Gasgas XC250
    image.jpg type in top left pic. Jus unroll em.
    Cheap as chips, stops ya packin gettin soaked with oil(so can reuse), won't burn/blow out/break down as easily n better sound deadening apparently. My wr300 muffler came from factory with it too.
    Might be a load of horseshit for all I know tho! :)
  10. Huskynoobee CH Sponsor ZipTy Racing
    Castaic, CA
    2011 TE449 2006 WR250
    Well I've got two silencers to pack. I'll have to give that a try Shawry. Makes sense to me. Thanks for the tip.
  11. HS507 Husqvarna
    NE Ohio
    Te 300
    Haha yeah strange in deed but i will try it out. Look for it at hardware store this week. And wrap white over top.
  12. shawbagga Husqvarna
    None
    2018 Gasgas XC250
    Like I said Ausky put me onto it. I also asked why not jus do whole packing with it but yeh rust be the issue. Wen I took stock silencer apart n saw that's how it came from Italy thought must be sumthn to it
  13. johnnyboy Husqvarna
    UK
    WR 125
    TM 250f
  14. shawbagga Husqvarna
    None
    2018 Gasgas XC250
    Nice video Johnny! Mellow yet trippy
    FYI never had any sign of rust as it's a 2t so normally a bit black n oily/carbony. Doesn't hurt anythin so can't see a drama with it. Agreed 2t don't generally run hot enough to burn packin but if u really wringin it's neck they still get quite warm(the core especially)! Plus like I say it stops the spooge runnin right through n soakin the entire packin rendering it useless basically. Please yaselves lads jus MHO.
    johnnyboy likes this.
  15. HS507 Husqvarna
    NE Ohio
    Te 300
    Oh now im definitely using wool!!!
  16. ggg Husqvarna
    TE250 14
    NONE
    repacked many 2 stroke they do not use the steel wool, even the stock replacement slide on ones are all fiber matt
  17. HS507 Husqvarna
    NE Ohio
    Te 300
    Fiber matt is very pricey, fmf packing 8.00
    Steel wool throwing sparks? PRICELESS
  18. blink_618 Husqvarna
    2017 te150
    2013 kx250f
    FMF usually has a support truck at gncc races and was talking with one of the guys there few season back about packing my 4t and he told me to use saran wrap. I had always used masking tape but the reason for the saran wrap was that the glue from the tape can get hot melt and make mess. Probably more likely on 4t than 2t but I switched to it and it gets job done. Melts away with no trace.
    dartyppyt likes this.
