Replace ADC automatic decompression cam TE models
Discussion in '4 Stroke' started by Duckman, Mar 28, 2017.
  1. Duckman Husqvarna
    Hi all,
    I am looking for a how-to for replacing the auto compression cam on my 2008 TE510. I think mine is worn out. The bike spins but does not start, untill i pull the manual lever for decompression and let it go again. Than the bike will fire up and runs like it should.
    Read a lot about the ADC and ordered the parts to replace it. has anyone a how-to for this? What are the things to look after to do it right.
    Tips and tricks needed ;) is it as easy as it looks?
  2. Duckman Husqvarna
    Email notifications on
  3. Duckman Husqvarna
  4. Trenchcoat85 Husqvarna
    Northern NorCal
    '14 TE 310R
    Make sure your exhaust valve is at the tight end of the spec (left valve IIRC); this is the biggest reason for the ADC not working good, it seems.
    I imagine- but do not know, that the spring and maybe the actuating arm are the big wear items.
    good luck.
  5. Duckman Husqvarna
    I ordered the parts for replacing the ADC, i will check the clearance also tomorrow. I have a ride on sunday.
    The parts will arrive later next week i hope. I am curious how difficult it is too replace the adc part. I only found one post on this forum that it wasn't that difficult but a How-To would be nice :)
  6. R_Little Husqvarna
    NJ
    No cams on Ebay?
  7. Duckman Husqvarna
    Didn't look on eBay. Called my dealer and the parts were only €69 ($73,50) now looking for the tips and tricks for the actual replacement
