250-500cc Replace or Not Replace???
Discussion in '2 Stroke' started by Clete, Jul 9, 2012.
  1. Clete Husqvarna
    Tigard, OR
    '01 CR/WR 250, '13 650 Terra
    '06 Suzuki SV650 (gone)
    The wishbone link of the rear suspension linkage assembly, has a big gouge out of the side of the arm. It looks like the bolt may have been installed from the wrong side, and the bolt hit the side of the wishbone link arm? The arm is approximately is 3/8"thick x 7/8", and the gouge is about half that in both directions.
    Replace or see if it holds up??
  2. huskybear Husqvarna
    B.C. Canada
    I would replace it,especially if you race. If it breaks while riding it could get ugly:eek:. Plus, if you change it, it's a good excuse to give the linkage bearings a little love:thumbsup:.
  3. Xcuvator Husqvarna
    Scholls Oregon
    yes
    Boy you've had your share of out of ordinary problems. If it's gouged halfway through, you should probably do something with it. How about checking at work and see if one of those fitters will weld it?
  4. Clete Husqvarna
    Tigard, OR
    Ya i was comparing parts prices, I know there are bearing issues
  5. Clete Husqvarna
    Tigard, OR
    Good idea, I will ask around. You had mentioned the guy in Newberg that could weld good.
