Replacement fan
Discussion in '4 Stroke' started by Joliet, Jul 6, 2009.
  1. Joliet Husqvarna
    Vista, CA
    My billet radiator guards did a good job of protecting my radiators this weekend, however my fan took a shot and broke the plastic mounting bracket that attaches it. We were riding some tight single track and I didn't notice that it was broke until the fan came on. I heard this noise and thought I got a stick stuck in my wheel, I looked down and the fan was on and bouncing all over my engine loosing pieces of blade whenever it hit.
    My question is; is there an quality alternate replacement out there (no computer fans), or do I just suck it up and order one from the dealer? Thanks, Ken
  2. lairpost Husqvarna
    Vista, CA
  3. HuskyMax Husqvarna
    WV
  4. bower100 Husqvarna
    Wilmington, DE
    '83 250CR - '07 TE450
    TY350Trials-BetaRev3-'77RM250-'80YZ
    Good find HuskyMax. I paid $75 directly fron Spal.
    Dave
  5. Joliet Husqvarna
    Vista, CA
    Thanks guys.
  6. Joliet Husqvarna
    Vista, CA
    For any of you that want to order one of these fans, here is the DL. I tried to order one online from the above site, and their order screen froze up at the last click (twice). In the end I didn't know if I had ordered zero, one, or two fans. I tried to call them, but they only have a fax number. I emailed them asking for a phone number, or to call or email me and I gave them my number. I received no response, so I called my credit card to verify that no charge had been made to them, then I ordered the part from the company below. It was a smooth transaction, with people you can call and talk to if there is a problem.
    Does anyone know if the wiring connecters on the fan are the same as on the bike?
    Ken
    http://www.a1electric.com/catalog/cat_spal.htm
    UPDATE; fan is back ordered, should know tomorrow the approximate delivery date, until then I will have to bypass slow single track.
  7. HuskyMax Husqvarna
    WV
    Sorry about the crappy service, I just done some quick research for another guy and that site had a lower price than the other places I seen.
    The plug does look the same, but I cant be sure without a closer pic.
  8. Joliet Husqvarna
    Vista, CA
    Update; Spal USA does not have any in stock, nor did any of the half dozen distributors that I tried. These are on back order until the next container arrives in August. This is the exact part that is on the bike, so it is an easy replacement, as it has the correct connector.
    The husky part number is 8000A7715
    Spal # is 30103018 or VA32-A101-62A
    If there is a sticky for replacement parts, maybe the above info should go there.
    30103018 Weight: 1 lbs. VA32-A101-62A Fan (4")
    4" Paddle Blade Low Profile Fan / 12V Puller
    From our low profile fan line this fan is ideal for oil cooler applications also popular in the motorcycle and ATV industry. It features a fully sealed waterproof/dustproof motor. Each fan is individually balanced for long life.
    Ken
  9. HuskyMax Husqvarna
    WV
    There is one on ebay. Do they have to have them in stock to post there. I'm not familiar with the rules on ebay. http://cgi.ebay.com/ebaymotors/4-Paddle-Blade-Motorcycle-ATV-Fan-Spal-Thin-Line_W0QQcmdZViewItemQQ_trksidZp3286Q2em20Q2el1116QQhashZitem2ea5985d48QQitemZ200346721608QQptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories
    I just wanted to add that the push fan part numbers are very similiar ( you dont want these VA32-A101-62S and 30103019 ) and not to be confused with the pull fan part numbers.
  10. bower100 Husqvarna
    Wilmington, DE
    One more thing to add. When I got mine from Spal several months back they mentioned to me it was unadvisable use a "push" fan in place of a "pull" fan, ( by reversing the polarity of the two wires). Even though the fan would run in the opposite direction it will not perform the same.
    Dave
  11. Swampds Husqvarna
    Sarasota Florida
    I called doc'sBLOCKS and they had them in stock for $49.95. I will update this once it arrives.
  12. Swampds Husqvarna
    Sarasota Florida
    The fan showed up like promised! Now I need to find the time to install it.
