Replacement fuel pump 2008 TE450 in Panama City!
Discussion in '4 Stroke' started by sneax, Mar 6, 2019.
  1. sneax Husqvarna
    2008 450TE
    Lambrettas, Yamaha, KTM
    Hi all
    I am a traveler with an Camper and a 2008 TE450 with me!
    Yesterday my fuel pump failed completely ... after a week of backfire and searching the problem!
    So I need to get me a new fuel pump!
    The problem is - I am in Panama right now!
    Shipping the part from US or Europe will take 12 to 14 days and its hard to find a shop who ships to Panama!
    I would like to avoid that waiting time .... since I plan to cross over to Colombia soon!
    Does anyone know a fuel pump that might fit into the original fuel pump assembly, from another Bike or Car? Like from an Yamaha or Honda .... where I have a better change to find one in Panama???
    Thank you so much
    Guido
  2. Trenchcoat85 Husqvarna
    Northern NorCal
    '14 TE 310R
    it's a 30mm diameter pump (standard size for lots of motorcycles snowmobiles quads); cars tend to have the 38mm diameter pump- although this is changing to a cartridge style.
    people have made the 38mm work but it's kinda mickey mouse.
    you can find either pump on ebay for $4-$400. So, yeah, more than likely ANY 30mm diameter 12v pump for anything will work (inc Honda, Yamaha). BTW, if you buy it at a US auto shop $30-$70; but if you buy it at a mc shop $50-$100. Panama may go cheaper, actually, if not brand specific.
    I searched on a TE510 but it's the same:
    sneax likes this.
  3. R_Little Husqvarna
    NJ
    I'd get one with barbs on the pump outlet, to make sure the hose does not come off while riding.
    It's happened to me.
  4. OlderHuskyRider Husqvarna
    Austin, TX
    Kwaka KLE, HD FXDWG
    You can get 38mm fuel pumps at any auto store, ask to look at the supply of small, toyota, etc 1.5 inch diameter (38mm) pumps, try to get one with a flare on the hose-connect outlet. You will have to remove the white 30mm bracket and replace it with a threaded rod to zip tie the larger 38mm pump to. see pic with larger 38mm pump, i unfastened the pump to replace the strainer
  5. Trenchcoat85 Husqvarna
    Northern NorCal
    '14 TE 310R
    If Panama is filled with those Chinese scooters, find a repair shop. Most of them that have a pump use the 30mm diameter one.
    I gotta imagine you're going to have to do a lot of "winging it" with mechanical issues when you get to South America.
  6. Trenchcoat85 Husqvarna
    Northern NorCal
    '14 TE 310R
    Confirm your pump is not working by applying 12v directly to the external wires.
