125-200cc Replacement Wheel Spacer Material?
Discussion in '2 Stroke' started by freezerGeezer, Feb 21, 2017.
  1. freezerGeezer Husqvarna
    Norfolk, UK
    2004 CR 165
    Looking for some advice on this.....
    Going to have some replacement wheel spacers made for my 04 CR125, just wondering what the best material would be to use?
    Should I stick with aluminium, if so any suggestions on what grade to use?
    or
    Would it better to go with stainless? Obviously heavier but the seal wouldn't wear grooves into it like the original alu ones, but I guess the seals would wear rather than the spacer?
    Any thoughts?
    Also attached drawing, may help someone else:rolleyes:
  2. ohmygewd Husqvarna
    Melbourne, Australia
    Aprilia RSV1000
    I'd go stainless TBH, wow so it may weigh a few more grams than aluminum but, as you stated, it will last longer!!
  3. shawbagga Husqvarna
    Eaton, Western Australia
    None
    2018 Gasgas XC250
    Been running the stainless spacers for years & they still show next to no wear!
  4. Zomby woof Husqvarna
    Ontario, Canada
    2011 CR 150
    I machined new ones out of 6061 T6 aluminum, but I have time, and material, so I can make them again if they wear. If the weight is not an issue, SS is the way to go
  5. SmokeyExpress Husqvarna
    Canberra Australia
    2014 WR300, 1996 WR360,2013 WR125
    Weight difference will probably not have much of a huge effect on unsprung weight. Personally when I have to machine spacers up I usually head to my local engineering supply & see what offcuts he has!
    :D
    Either material would work well!
  6. freezerGeezer Husqvarna
    Norfolk, UK
    2004 CR 165
    Thanks Guys:thumbsup: I'll go with what ever material is available at the time.
  7. Hurky Husqvarna
    Spain
    ex: WR300 2010
    Honda CR500AFX + Beta RR300
