250-500cc Replacing water pump seal on 07 WR-250
Discussion in '2 Stroke' started by tree dodger, May 22, 2010.
  1. tree dodger Husqvarna
    I believe the impeller is reverse threads. If so, do I turn the impeller clockwise to remove it. To replace the seal and o-ring, do I have to remove the side case and pull out the shaft. If the case does have to come off, is it better to pull the impeller first so the shaft doesn't turn.
  2. franhoser Husqvarna
    Maple Ridge, BC
    did you get an answer to this? if so I wouldn't mind some advise as I belive my water pump seal also failed.
    thanks
