ray_ray
Mini-Sponsor
DISCLAIMER: Just trying to make a dollar out of 50 cents again here ...
I'm off in another section of the cafe where the word is to use 0w-40 oil to help the xlites engines to maintain proper engine oil flow characteristics on the higher 40wt side of the oil, helping the engine last longer before repairs ... The lower temp rating helps the oil flow at start-up times ..
So, from the oils I had to pick from here on Cebu, with costs also taken into consideration, I ended up with this 50wt and 30wt stuff blended at an attempt to hit ~40WT...
Someone then points out that Mag1 oil has "Friction Modified For Extended Wear Protection." That's not good for the clutch.... OK but I'm not 100% what that means, but will venture it means the clutch will slip too much? Or does it mean the plates \ fibers will not last as long? This was the 50 cents moment needed for trying to make a dollar
Final DISCLAIMER: Do not try this oil blending under your own shade tree unless you are a responsible type person.
-- Testing riding with FMX begins!
One of the larger and twisty climbs I know here is heading west, just east of Lusaran, heading up and over a small mountain ridge. What better place to test a clutch for slippage except for up a pretty good grade in some hard turns? (I've also rode the bike the day before so I'm pretty sure the bike is ok or else I'd never go this far on a bike that might fail).
This ride is called the 'Lusaran Ridge' Ride ... Here are a few pics at the intersection for heading over the ridge or turning to go straight into Lusaran proper.
That ridge line in the background of my 010 TC250 is hiding Lusaran and the larger ridge we'll be riding over and testing the FMX oil additives package against the Husky clutch action.
This is the real ridge line above Lusaran that we will ride to the top and then we'll ride a spur off the top.
Coffee plant here I think ... There were loads of them planted here just a few months back but it seems new owners have moved in and replanted some of the area.
