My right side radiator is leaking, not sure if hose connection point or some point on the radiator itself. How does one differentiate, when nothing visible is seen except for coolant? Also where would i find a new radiator and/or new radiator hoses(specifically the Y one) bike is a 2009 te610.
update: used a wire brush to cleanup radiator and was able to find a microscopic leak under the top outlet pipe....tried to aluminum braze it...didnt work lol. So now im on a search for a 2009 te610 right radiator, where might i look for this?
there doesnt seem to be a 2009 te/sm610 option? The latest is an 08, does an 08 610 use the same rads as the 09?
I don't think the radiators changed between those years. Email or call Hall's and they'll tell you, or download the parts diagram from each year from the Hall's site and compare part numbers.
