250-500cc ring gap size please
Discussion in '2 Stroke' started by shawbagga, Sep 6, 2014.
  1. shawbagga Husqvarna
    Eaton, Western Australia
    None
    2018 Gasgas XC250
    whats its supposed to be for the wr300s? do I measure it from top or bottom of cylinder? thanks all
  2. juicypips Husqvarna
    gloucestershire
    wr 360. 2002
    Not sure what it is but put the ring in cylinder about 10-15 mm down use the piston to make sure its square, measure that.
  3. shawbagga Husqvarna
    None
    2018 Gasgas XC250
    yeah did that pips, got around 0.009"-0.010"(0.22mm-0.25mm) measuring from the top. cant find actual specs
  4. juicypips Husqvarna
    gloucestershire
    wr 360. 2002
  5. shawbagga Husqvarna
    None
    2018 Gasgas XC250
    sweet mate cheers. wossner piston but sounds like im pretty close then at 0.010"! fired it up with the new piston kit, plus new lectron 38, reeds, rad hoses, kicker & she runs nice on the stand. hope its all ok:thinking:
  6. juicypips Husqvarna
    gloucestershire
    wr 360. 2002
    Well if thata what you calculated cant see why it shouldnt be fine.
    Good luck
