Rocker lever linkage MOD
Discussion in 'Common Items on Husqvarnas: Tires/tubes/grips/etc' started by ray_ray, May 27, 2012.
  1. ray_ray Mini-Sponsor
    The Philippines
    I finally got tired of the hassle of removing the 4 bearings in the rocker lever assembly by driving each out in the opposite direction it went it due that center ridge in the rocker ...
    Without this ridge blocking the bearings, I should be able to use a socket and drive both bearings out the same side .. . I hope to add the zerts next for easier greasing ....
    OlderHuskyRider likes this.
  2. PALMER84ONE Husqvarna
    Silverado, CA.
    08 TE450 THE ROCKET
    12 RS520, CRF150F/230F, YZ250
    Are you going to replace the ridge with a spacer so they stay in the same place? You don't want them to squeeze together and be in the wrong location..
  3. ray_ray Mini-Sponsor
    The Philippines
    I don't plan to add anything ... I don't see the bearing moving really as they are always very tight removing or adding back in place ...
  4. OlderHuskyRider Husqvarna
    Austin, TX
    Kwaka KLE, HD FXDWG
    Ray, what did you use the get rid of that ridge, I need to do that as well, that ridge really ruined my day.
  5. ray_ray Mini-Sponsor
    The Philippines
    I think the guy just used a vice to hold it and a long drill bit to smoothed it out inside there... That's not hard material there ..
