Rod spry... Is the man
Discussion in 'Vintage/Left Kickers' started by megagobby, Nov 11, 2010.
  1. megagobby Husqvarna
    thanks rod your a star!:thumbsup::thumbsup::thumbsup::thumbsup::thumbsup::thumbsup::thumbsup::thumbsup::thumbsup::thumbsup::cheers::cheers:
  2. glangston Husqvarna
    2012 Husqvarna TE 310
    2012 BETA 350 RS
  3. HuskyT Moderator
    Corona, California
    Enlighten us please Obi-Wan.....?
  4. megagobby Husqvarna
    rod spry engineering vintage motocross specialist . (google it) he done work for me on my husky and he is the dogs danglers :thumbsup:
  5. Murph Husqvarna
    UK
    Told you he would sort you out.
  6. Murph Husqvarna
    UK
    Was it the gearbox problem he helped with?
  7. megagobby Husqvarna
    yes murph .thanks to you and rod . its all sorted now cheers fellas :thumbsup:
  8. Murph Husqvarna
    UK
    I am really pleased with the work Rod has done on my engine. It looks great and he kept the price very sensible considering the work it had done to it. There were holes in the cases that had to be magnesium welded and every part in the gearbox needed to be stripped and cleaned because water had gotten into it and caused loads of corrosion.
    I just need to sort my ignition out now and my motor will be as good as new.
    I never did suss out why the pictures on my restoration thread disappeared, but I will be putting more on there soon, hopefully this weekend.
  9. megagobby Husqvarna
    yes murph hes spot on . please post the pics of your project i would like to see them mate cheers
  10. megagobby Husqvarna
    whats the probem with ignition ? i got my complete ignition from electrex world there good mate , give them a bell.
  11. Murph Husqvarna
    UK
    I have been told by a very knowledgable source that I have the wrong stator. The resistance values are not correct for the stator that should be fitted to it. It probably works, but won't work with that motor. I guess maybe a previous owner had a problem and tried replacing it with a used stator, but unwittingly fitted the wrong one and never got it going again. Who knows for sure. Anyway, I may have found one, but if not, I will buy a complete new ignition.
    Which Electrex ignition did you buy? Is it the internal rotor version? What size is the taper on the rotor, do you know? They have just added an external rotor version to their Husky range, so that might be worth checking out. Electrex are certainly good value compared to PVL or Power Dynamo (formerly MZB).
  12. grouty Auto Lover ...
    South West UK
    78 390WR, 78 390 AMX, 500 Humph
    works 73 CCM 520, another 73 CCM520
    Bobby, I am sure I saw your motor when I was at Rod's last. If he breathed life back into that ..... wow ! Those cases were bad !
  13. Motosportz CH Sponsor
    Cool stuff. I want this...
  14. Murph Husqvarna
    UK
    That was my motor Grouty. The cases needed welding up because of the holes from the water in the motor. You'd never know it had been done looking at it now. :thumbsup:
  15. megagobby Husqvarna
    yes its the internal rotor one. (stk-019) i had to send in my motoplat rotor for them to machine the taper . but all good. :thumbsup:
  16. megagobby Husqvarna
    really? i thort my cases was in good condition to be honest. maybe they was some one elses ? what makes you think that the cases were mine?:confused:
  17. Murph Husqvarna
    UK
    Don't worry, it was my 390 motor that had the holes in the cases. But no holes there now :notworthy:
