TE/TC Rotella T choices
Discussion in '2st' started by HS507, Oct 20, 2016.
  1. HS507 Husqvarna
    NE Ohio
    Te 300
    Yz450,crf150r,crf100f,crf50f
    No, this is not an oil thread hsha
    Anyone know if all 3 types are ok for clutch? Rotella t4,5,6?
    I use 4 now 15-40w but was wanting to try lighter for winter, like 5-40 or 10-40. Does any of you go lighter in winter? Please no debates or arguing with each other, just want opinions that are conducive to my inquiry
  2. NCSteve Husqvarna
    Appalachia
    12 WR300 13 WR165
    02 XR250R 00 XR100R
    I just switched to Rotella from Mob1 in the 165. Tried T5, but had a lot of clutch drag when hot. Then T6, 1 race and 2 rides and no issues.
    Full synthetic oil should flow better in cold temps. Not sure if 0/5/10-40w makes a big difference.
    :cheers:
    JAM likes this.
  3. HS507 Husqvarna
    NE Ohio
    Te 300
    So you
    use Rotella T 15-40 like i do?
  4. NCSteve Husqvarna
    Appalachia
    12 WR300 13 WR165
    02 XR250R 00 XR100R
    I'm using T6 5-40w, good price on gallons at Advance Auto.
    JAM likes this.
  5. Hurky Husqvarna
    Spain
    ex: WR300 2010
    Honda CR500AFX + Beta RR300
    We have no Rotella here in Spain but I was using 15W50 Mobil Delvac MX and was satisfied with it, never tried an synthetic HDEO..
  6. Kevin_TE250 Husqvarna
    Boise Idaho
    I mix half and half... since I have both bottles... :)
  7. Zomby woof Husqvarna
    Ontario, Canada
    2011 CR 150
    As long as you don't see the energy conserving label anywhere on the bottle, you will not have any clutch slippage problems. Rotella is a diesel oil, so that's not an issue
    Picklito likes this.
  8. PawPaw Husqvarna
    2013 TC 449
    Honda Crf450R + old CB750
    T6 is the best out there. It is wet clutch rated. I use it in every thing I own that has a fuel burning 4 stroke engine.
    Paw Paw
  9. justintendo klotz super techniplate junkie
    mercer, pa/northwest pa
    99 kawasaki zrx 1100
    t4 and t6 are jaso ma rated....t5 is not....
    oldbikedude and NCSteve like this.
  10. HS507 Husqvarna
    NE Ohio
    Te 300
    Thanks guys
  11. 268fords Husqvarna
    Powell, Wyoming
    08' TE510'
    Mobil 1 0W-40 and haven't looked back. Clutch felt better than it ever had before. All my bikes get the Mobil 1 now
  12. Picklito Husqvarna
    Washington
    430, 430, 430, ,400, 175
    KTM250xc, KTM500mx, KTM440exc
    NOT having the energy conserving label is the first thing to check for if you want to use any oil in a wet clutch motorcycle. A+ to Zomby woof.
  13. HS507 Husqvarna
    NE Ohio
    Te 300
    This site is full of smart guys
  14. racemx904 Husqvarna
    owenton, ky
    2014 Beta 350RR & 1986 430XC
    T6 I use the same 15/40 year round....
  15. oldbikedude Husqvarna
    Honey Brook Pa.
    & me
  16. HS507 Husqvarna
    NE Ohio
    Te 300
    Yes and you too.
    I love it when people make up my mind for me
  17. robertaccio Husqvarna
    San Diego, Ca
    2021 Husqvarna TE300i
    I am not going to join another oil thread...ooops I just did.
    I wont say what to use for your 2T gearbox, use what you want.
    But I will say I use the very lightest viscosity in my gearbox/clutch all the time and have gone this route since the early 90s. And I just change it often to keep it fresh. (Maxima MTL XL 75wt).
    For example for the moment- 1 trail ride and the National Hare and Hound final=oil change. normally I change 150- 200 miles, Rekluse and lots of technical stuff = lots of clutch slipping= heat heat and dirty oil.
    I always use moto brand oils from Spectro to Maxima to Motul to Castrol to Belray, but I am a 95% Maxima customer.
    Yes I know this is a Rotella thread, just want to throw out the R-accio recipe.
    (BTW Rekluse (mine is Core EXP 3) has been known to recommend the use of Rotella)
  18. HS507 Husqvarna
    NE Ohio
    Te 300
    Hows 75w equate to regular non gear box oils (motor oils) like Rotella.?
    Like 10-30 type weight- light?
  19. Hurky Husqvarna
    Spain
    ex: WR300 2010
    Similar to a ~10W,15W, or low 20W depending on the Kinematic Viscosity, 75W has a big range so it would be better to compare the actual cSt that you can find at the datasheet of the lubricant.
    Regards.
  20. HS507 Husqvarna
    NE Ohio
    Te 300
    Wow 75w gear is like ATF thin looks like
