Royal Rods
Discussion in 'Vintage/Left Kickers' started by ajcmbrown, Jun 28, 2018.
  1. ajcmbrown Husqvarna
    Metung Victoria Australia
    400WR 250WR 07 WR500 430AE 360AE
    1985 500CR Ducati Multistrada 1200S
    Has anyone here had any experience with these conrods?
    https://www.kiwavmotors.com/en/parts/engine-transmission/connecting-rods
    I've heard good reports from Maico and KTM owners/builders.
    At the moment they do not produce a conrod for any Husky other than WR360 Huskagiva, 610, 630 and 97 on 125's.
    Is there enough demand for these if they were to make a rod to suit 250/400/430/500 engines?
    Tony.
  2. Joe Chod Husqvarna
    upstate NY
    Dave Pratt has a nice rod kit for the Swedish bike. 125 and all others (not sure on 500) tritrophy on e bay. great product
  3. GaryM Husqvarna
    Austin, Tx
    1981 430cr second 430 CR 500cr
    1981 490 Maico
    I tried communicating with them and had no responce. let me know what you hear.
  4. GaryM Husqvarna
    Austin, Tx
    1981 490 Maico
    Please note , would want a bit higher grade of steel if I remember what their standard was. Have to go back and check
  5. 2premo Husqvarna
    Northern NV
    Sherco 300, 2002 KTM 380EXC
    ajcmbrown likes this.
  6. ajcmbrown Husqvarna
    That's interesting Gary, I've seen to a couple of builders posts, Toby Opferman is a well known Maico dude who says they are good quality and a couple of KTM guys who recommend them as well, maybe they have improved over the years?
    Tony.
  7. ajcmbrown Husqvarna
    He has none listed at the moment, I will message him to ask if he has any.
  8. GaryM Husqvarna
    Austin, Tx
    1981 490 Maico
    Really its just a geek thing ! That metal type can work. Always looking at the utimate possible part or parts
  9. jimspac Husqvarna
    Connecticut
    86 400WR, 82 Montesa Cota 349
    What issue did you have with Hot Rods? I was impressed with their product after getting a 79 YZ250 con rod for a 250WR project I have going. It was more to save a good conrod to create a second 430 engine as I was going to build a 430CR. Since I can not find a 1982 CR frame, I am going to build a 1983 250CR and do some experimenting with porting and expansion chamber
  10. ajcmbrown Husqvarna
    I can't find a listing for 400/430 rods on their site, do you know if they make them jimspac?
  11. 86 400 XC Husqvarna
    Calgary
    75,82,83,2x84,85,3x86,87,88 and 89
    more Huskys
  12. jimspac Husqvarna
    Connecticut
    They do not make them. I was looking at rods they make that have the correct center to center dimension, the small and big end bearing journal sizes. I was going to check into having Hot Rods make rods to the specs that we need from the existing forgings that they would just machine to specs.
    I stopped after Gary wanted a bigger order but I believe he would have had to pay for the developement of the forging process. That is why I looked for the forging numbers that the 135mm con rod and the 500 could be made from forgings that were already developed. I was trying to avoid the deal breaker by doing the research myself.
  13. ajcmbrown Husqvarna
  14. 86 400 XC Husqvarna
    Calgary
    more Huskys
    Never had to deal with replacing a rod, no idea.
  15. 2premo Husqvarna
    Northern NV
    240, 250, 400 and 430 share a rod, it seems odd that the part number changed, the 85 400 rod vs the 87 400 rod being a different number seems very odd
    never really paid attention to that, now to wonder why, where is George when we need him
    paging mr. Erl
    86 400 XC likes this.
  16. Joe Chod Husqvarna
    upstate NY
    Dave Pratt info
    for 125 and also 240, 250, 400 and 430 rods
    David Pratt
    Tritrophy LLC
    20825 NW Old Pass Rd
    Hillsboro, OR 97124
    503.680.3056
    dpratt@tritrophy.com
    Go direct and save over evil bay....he will appreciate that too!
  17. Joe Chod Husqvarna
    upstate NY
    These Rod Kits are NEW Manufacture, not NOS.
    They feature beautiful Rod Design, Heat Treating, Ti Caged Bearing and 25.03mm Properly Heat Treated Pins.
    We have been having these kits and 125 Husky Rod kits manufactured for some time with Great Results.
      File size:
      120.8 KB
      10
    Picklito, 2premo, ajcmbrown and 3 others like this.
  18. ajcmbrown Husqvarna
    Just received an email (not an eBay message) from Dave, I'll be ordering one of his rods I think, thanks Joe.
  19. ajcmbrown Husqvarna
    I did read somewhere that the 87 and 88 rods were a little lighter in an attempt to reduce vibration.
    Tony.
  20. fran...k. Husqvarna
    eastern ct
    The 87-88 rods on cranks I have or have had are shaped more like an I beam than a popsickle stick. There are the little recesses at the wrist pin similar to the ones at the big end on the picture in post #17 above. I guess for better oiling. Never had one out of a crank so can not weigh but weight difference being lighter never came to mind looking at the differences. P3040403.jpg
