RPM Range
Discussion in '4 Stroke' started by hoffa509, Jan 30, 2010.
  1. hoffa509 Husqvarna
    Alexandria, Va
    The manual for my 09 TE250 says that the tach max's out at 14,500 rpm. The bike actually hits the rev limiter at 12,000. The reason I ask is that when I am going 65 on the road with stock gearing, I register about 9,000 RPM. My concern is what is a safe cruising RPM? I have a streetbike and a dualsport for real road riding, but I will be on the street with the TE from time to time to get between riding areas and to keep it in shape. So is 65MPH/9,000RPM too much? What is a safe RPM?
  2. hamiltonuh60 Husqvarna
    I'm no mechanical engineer but 9000 RPM sustained for a duration, I think that wouldn't be good for your engine. I take my 08 TE250 up to about 7000-7500 RPM just for a couple minutes on the highway since I live only three miles from work.
  3. CARL REHATCHEK Husqvarna
    Tamaqua, Pa
    2010 TE 250
    Do you have the 40 tooth on or the 50 tooth ???
    In the 50 tooth rear I would not do 60 for more then a mile or 2 tops as even bikes like a Suzuki Dr 250 doesn't sit well over 55 and the Dr 350's at 60 seem to be strained/labor when backing off the throttle.
    I'm sure they all could do it but on my own bikes I wouldn't push top speeds for reliability..
    Chow, Carl
