250-500cc Rubber intake & Reed cage don't match.
Discussion in '2 Stroke' started by yakka, Aug 15, 2016.
  1. yakka Husqvarna
    West.Australia
    WR300 '09
    When making new gaskets for intake boot on the 300 (2009),noticed the opening doesn't line up with the reed cage (original) opening. 3 sides are OK, but one is about 4mm off. Cage hole is offset to one side while boot is not. Same with the old original boot too. Tried rotating 180, same thing again.
    Anyone else ever noticed this?
    This would create a lot of turbulent flow. Think I might attack it with the file.
  2. juicypips Husqvarna
    gloucestershire
    wr 360. 2002
    Yup it's a common mod to increase air flow the 360's were very narrow on the boot so had to match to each other.
  3. shawbagga Husqvarna
    Eaton, Western Australia
    None
    2018 Gasgas XC250
    I got spare gaskets for reed block if u nd 1 mate
  4. yakka Husqvarna
    West.Australia
    WR300 '09
    Cheers shawbagga, been cutting my own gaskets-going thru some chasing what I thought was a air-leak.
  5. Hurky Husqvarna
    Spain
    ex: WR300 2010
    Honda CR500AFX + Beta RR300
    Interesting, I never checked if that is also the case on my 2010 WR300, next time I will check and use the file if needed :D. I suppose that there should be some noticeable gains from it...
  6. shawbagga Husqvarna
    None
    2018 Gasgas XC250
    She bn runnin lean or hangin throttle?
  7. yakka Husqvarna
    West.Australia
    WR300 '09
    Hanging throttle,pinging like mad. been thru everything ,can't work it out.
  8. shawbagga Husqvarna
    None
    2018 Gasgas XC250
    Post up wat uve dun maybe sum outside eyes/ears could help?
  9. Miezie666 Husqvarna
    Germany
    2x YZ 125, 1x YZ250 2005, XT600 2KF
    I never had any good experience with any v force in my bikes... my yz125 did not perform better, my wr250 was harder to start and didnt idle as good as it did with the stock intake and my wr125- i m not sure if this thing does help at all.
    The standard reed cage is not such a bad design.
    I had the best experience with the boyese rad valve- but i m not sure if its available for the 125cc engines.
  10. yakka Husqvarna
    West.Australia
    WR300 '09
    With my bike the VForce are the stock reed cage.
  11. Miezie666 Husqvarna
    Germany
    So on my WR125... but i did have an older reed cage for my 125 and 250.
  12. oneal Husqvarna
    uk
    1999 wr 250 returned home.
    07 TE 450 2005 TE 450 1999 CR 125
    it will be interesting to find out whats going on with the hangin idle
  13. yakka Husqvarna
    West.Australia
    WR300 '09
    Wasn't air leak,like I thought. But the throttle slide being set too high (idle-screw). A Lectron quirk.Resulted in running lean with closed throttle.
    Had to lean out rod until it stopped hanging.
  14. shawbagga Husqvarna
    None
    2018 Gasgas XC250
    Where'd measurement ya end up at with rod n idle screw yakka?
    Hope ya didn't spend too much on it buyin parts to fix the prob
  15. robertaccio Husqvarna
    San Diego, Ca
    2021 Husqvarna TE300i
  16. yakka Husqvarna
    West.Australia
    WR300 '09
    No, most of it about due to be replaced anyway. Wasted a lot of hours going in circles though.
    50.5mm seemed to cure it,but bottom-end feels a bit lean. I'll take it out this arvo & see how it goes.
  17. yakka Husqvarna
    West.Australia
    WR300 '09
    On the slide you mean?
  18. Huskynoobee CH Sponsor ZipTy Racing
    Castaic, CA
    2011 TE449 2006 WR250
    On the reed cage. Now I'm curious too.:rolleyes:
  19. shawbagga Husqvarna
    None
    2018 Gasgas XC250
    Try it 1/4 richer if no good. Think 1/4 turn is equivalent of 0.25mm from memory. Let us know how she goes
  20. Thack Husqvarna
    Houston, Tx
    2002 CR250
    YZ426F, Ducati 748, Suzuki DR125
    I have a feeling V-Force used an existing casting from say a Honda and sold it to Husqvarna.
