Sae 20 Substitute
Discussion in 'Vintage/Left Kickers' started by Quimo, Sep 1, 2020.
  1. Quimo Husqvarna
    1986 XC400
    72 Triumph Bonneville 650, 13 YZ450F
    I just acquired a 1986 XC400 and would like to give it a good once over before I ride it regularly. In looking at the manual it recommends SAE20 for the crankcase oil, but it is proving a little hard to find. Is 5w-20 an acceptable substitute?
  2. 86 400 XC Husqvarna
    Calgary
    75,82,83,2x84,85,3x86,87,88 and 89
    more Huskys
    Use ATF type F, easy to find and the clutch and gears will love it..
    1 of my favorite bikes the 86 400 XC, congrats on the bike.
    :cheers:
  3. DeathFromAbove My Cat Says AREAR!
    North New Jersey
    70,71 360 8s 72,74 450 73 360 73 250
    66 Triumph Trophy 99 ZRX1100
    Steve, you use F type in the manual trans?
  4. motomwo Husqvarna
    Imbler Oregon
    Many vintage big bore and automatics
    Torco MTF-L
    DeathFromAbove, markt2 and 2premo like this.
  5. 86 400 XC Husqvarna
    Calgary
    more Huskys
    I do ;)
    DeathFromAbove likes this.
  6. 2premo Husqvarna
    Northern NV
    Sherco 300, 2002 KTM 380EXC
    I use a synthetic oil also, or Torco MTF-L like motomwo says above
    MTF is a manual transmission fluid for a gearbox that is not directly affecting the crankcase, ie a 2 stroke
  7. markt2 Husqvarna
    Nevada
    1976 250CR (times 2)
    Several vintage Yamahas
    Torco light gear oil (now MTF-L) is what I've used since Malcolm Smith recommended it when I got my new 1976 Husky from his shop. Good stuff. Made for these transmissions and clutches.
  8. DeathFromAbove My Cat Says AREAR!
    North New Jersey
    What weight is standard?
  9. 2premo Husqvarna
    Northern NV
    this is almost worth a long discourse on "lubricity" vs "clutch grab"
    so without going into how viscosities are determined, and yes it is interesting
    lets look at how much grip you want and how much gear protection you are willing to trade
    if you can't effectively use your clutch then the gearbox is pretty useless in the real application
    so type "F" atf is mentioned, it has a "grippy" property and as such makes a light clutch grab well
    light clutch??? yes the trade off for a clutch that won't wear out your forearm but will grab with modern power
    so,,, the trick is to protect the gears, as they are expensive to replace, have a clutch that you can use and not get arm pump
    I personally use all the modern science I can, I use synthetic MTF, the reason for using synthetic is the difference in time, how often do you change your gear oil
  10. Quimo Husqvarna
    1986 XC400
    Thank you for the responses! I ordered some of the recommended Torco, but will definitely be keeping an eye on this thread to see where it leads...
  11. Hurky Husqvarna
    Spain
    ex: WR300 2010
    Honda CR500AFX + Beta RR300
    I don't know that particular bike but I am having good results with UTTO 10w30 oil in my two stroke gearboxes, using it for years with good clutch and transmission feel, fewer debris on the drainplug magnet as well.
    DaveM, DeathFromAbove and justintendo like this.
  12. justintendo klotz super techniplate junkie
    mercer, pa/northwest pa
    99 kawasaki zrx 1100
    i never liked the atf type f in my swedes..too many shavings on the magnet, and type f is thinner than the average 20wt..
    for years now ive been using rotella t6 diesel 5w40, which is a bit thicker but produces MUCH less material on the magnet and still shifts nicely. much better anti-wear additives in a diesel oil than atf, and much more resistant to shear. rotella t4 and t6 are both jaso ma rated.
    atf is around 5-7 cSt@100 degrees,
    20 weight oil is anywhere from 6-10 cSt@100 degrees
    the published "weight" of an oil doesnt mean much, the centistroke rating is much more accurate, and is usually easily gotten from an oils website
  13. justintendo klotz super techniplate junkie
    thats because 10w30 is a stout oil, and fairly close to the original recommended weight.
    DaveM likes this.
  14. justintendo klotz super techniplate junkie
    "gear" oil that is sae 80w...is the same thickness as almost a sae 30w "engine oil"
    a 75w gear oil that played nice with a wet clutch would be ideal and provide excellent gear and bearing wear. the torco mentioned above fits this perfectly
    motomwo, DeathFromAbove and 2premo like this.
  15. 1 Wheel Drive Husqvarna
    Eastern Vermont
    1988 Husqvarna 250 XC
    FJR, Africa Twin, Triumph T100
    Seems odd that a 75W gear oil would be a proper substitute for 20 weight engine oil. The gear oil would surely be great for the gearbox, but I can’t believe that the clutch would behave the same. There must be a reason that Husqvarna originally specified such a light viscosity oil.
    At least the gear oil wouldn’t have any friction reducing additives like most modern automotive motor oils do. I’m inclined to try using a good motorcycle JASO MA rated 10W30 as that will be closest to what was originally specified. 5W20 oils would be closer in viscosity to straight weight 20, but none of those would be JASO MA.
  16. motomwo Husqvarna
    Imbler Oregon
    Yes 75wt gear oil is the proper substitute for 20 wt motor oil. I have been using Torco MTF-L 75wt in all my manual clutch Huskys. No clutch drag or slipping.
    Marty
  17. SteveJ Husqvarna
    New Mexico
    1970 400 Cross, 1983 500 CR
    84 Honda CR500R, 81 Honda CBX,
  18. Quimo Husqvarna
    1986 XC400
    For what it is worth, I have been using the Torco MTF-L (75wt) in my 86 XC 400 for about 2 years, per recommendations on here and have had no issues.
  19. 1 Wheel Drive Husqvarna
    Eastern Vermont
    Thanks. I’ll give it a try.
