Safari Tank wiring caution
Discussion in 'TR650' started by KiwiTR, Mar 7, 2022.
  1. KiwiTR Husqvarna
    Hi all,
    Have been chasing an intermittent dash fault on my Strada and found the spigot (replaces the bolt holding the top subframe rail) on my RH Safari tank was rubbing on my main wiring loom due to the thread of the spigot being approx 10mm too long. Might be worth a check if you are running Safari tanks. I ended up shortening the thread by about 5mm and putting a rubber cap on the end to prevent it getting worse. Not sure if it was the source of my problem, but the dash has behaved on a 50km ride so far….
    Daniel bam likes this.
