TE/TC Sand getting by Air filter on 2014 TC250.
Discussion in '2st' started by Hal_396, Jul 22, 2015.
  1. Hal_396 Husqvarna
    2014 TC-250
    1997 CR-250
    When I serviced my air filter I noticed that a small amount of sand was getting in at the very bottom of the filter. No matter how much I greased it up, sand still sneaked by. When I put the 300 kit in I put that foam weather strip, 3/8" thick, all around the mating surfaced of the airbox and so far it has worked very well at keeping the sand out. Anyone else noticed this on there bike?
  2. robertaccio Husqvarna
    San Diego, Ca
    2021 Husqvarna TE300i
    No I have not had this issue personally.
    But the ZipTy Racing team guys did and Ty Davis worked with the team filter sponsor UNI filter to design a compatible filter with a 2 layer sealing surface. They found that the filter sealing edge would walk away from between cage lip and boot sealing surface and slip out (sounds like this is your issue).
    This is (will be) marketed as a ZipTy Racing product by UNI. Photos have been shot for posting soon.
    I'm sure if you call ZipTy they may be able to sell you one, before it hits the website store.
    Portland2stroke likes this.
  3. bikesparky Husqvarna
    Townsville Oztrailia
    FE501
    Superduke 1290
    Others have reported this and it seems to be the plastic subframe bending, might be why they put an extra screw in it from '15 models on.
    I fitted a washer over the center pin so it pushes the filter down a bit harder as suggested on some KTM forums and I never had a problem.
    Used a 2mm thick plastic washer and drilled the center hole to size.
  4. Hal_396 Husqvarna
    2014 TC-250
    1997 CR-250
    Good to know it wasn't something I was doing wrong.:o
  5. rancher1 Husqvarna
    WA
    The sand just gives you a big bore.
    robertaccio likes this.
