Hello, I just bought a Scottoiler V-System, and was wondering if anyone has fitted it to the TR 650 and could advise the best way to do so. I contacted Scottoiler direct and they mentioned they have not done this to a TR 650 yet. Thanks
My concern would also be using the oiler off road. Won't the oil buildup and cake on dirt and grit?
even in dusty conditions the chain remained quite clean and didn't end up caked with oily dirt.
Chain stays clean...but where does the oily dirt end up??? I remember lubing my chain on other bikes and not letting it dry. Man you rear fender and pipes sure pay the price for oil and dirt sticking to it.
jupB, did you get your scottoiler installed? Any pics? I want to put one on my StradaActually, it is quite straightforward, the bike has a vacuum tube which is easily accessible on the front right side, the pump can be attached to the front left. I'll post some photos in a couple of days. All you will need is a 6mm grommet to connect to the vacuum tube, Scottoiler supply this free of charge - their customer service is excellent (the standard grommet is 4mm).
Thanks
--Chris
Chris
There are no vacuum pipes on the Terra, its all incorporated into
the top of the throttle body.
I've just managed to get the manifold off after a couple of hours,
seat, side panels, radiator side panels, exhausts off then top and
bottom sub frame bolts out, lower the sub frame. This allows you
to take out the airbox screw which is hidden by the petrol tank.
There is enough room to wiggle the top of the airbox up by pulling
up the tank. You can then slacken the top clip and take off the two
bolts that hold the manifold to the head. Now to drill and tap it and
put it all back together, I hope its worth it !
Scotty
JupBa, do you have a pic of the vacuum tube you tapped into?
Thanks.
--Chris
Chris
Scotty
