Scotts Steering Stabilizer
Discussion in '610/630' started by jarthur, Mar 10, 2010.
  1. jarthur Husqvarna
    El Dorado Hills
    Hello:
    I just was introduced to this site by Dan at MotoXotica. Have not had a chance to browse the discussions but plan to do so.
    I have a 2006 TE 610 and am trying to install a Scotts underbar stabilizer. My upper fork clamp (45 mm forks) has bar mount spacing of 85 mm (the distance between the center line of the bar mount bolts). I need one with the 93 mm spacing. Any part number from Husky, an aftermarket upper clamp, or advice?
    Many thanks for any help..
    Jack
  2. Doormandan Husqvarna
    So Cal
    I used a Scott's under bar mount on my 08 TE610 that came off my 2007 TE250 and made a pin off the upper tank bolt. I had to mod the arm off the steering dampener to reach the pin. the pin was made in my shop (crude) for a test and has been on a year now and has held up well, I have great intentions to machine a better pin with a base to match the original washer.
    Note: I did have to buy longer bolts and stover nuts to mount the bar clamp on to my 610.
    Dan L
  3. Jodiesel Husqvarna
    Aiea, HI
    TE610
    How much higher are your bars now?
  4. Doormandan Husqvarna
    So Cal
    Not sure it looks to be about 1" I never took a original measurement but if you let me know what yours is stock I will check it on my Scott's set up.
    Dan L
  5. ghte Husqvarna
    Bright, Victoria Australia
    Nicely done DanL. Looks great. It seems you are well set up for true dual sport riding.
  6. Jodiesel Husqvarna
    Aiea, HI
    TE610
    From the top of the triple clamp (not the nut) to the top of the bar is approx 2.5".
  7. Doormandan Husqvarna
    So Cal
    With my Scott's it is just under 3 1/2"
    Dan L
