sealing/protecting un unused connector plugs
Discussion in 'Common Items on Husqvarnas: Tires/tubes/grips/etc' started by bhima, Nov 4, 2012.
  1. bhima Husqvarna
    CAMBRIDGE UK
    2012 310. 05 510. 04 WR250
    CCM R30 644. BETA REV 3
    ive taken the lights and controls off my te 310.012
    are there plugs to connect to the unused terminals or whats the best thing
    i do alot of off road mud and sand!
    thanks
    just luvin the bike:)
  2. KXcam22 Husqvarna
    Kamloops, BC, Canada
    2011 SM630, 2017 300XC
    08FZR6;07CRF450;98CBR900RR;02KTM200
    Wrapping them well in some electrical tape should be sufficient. To go the extra mile you could push some dielectric grease inside the connector and then tape, but the tape alone should be fine. Hope this helps. Cam.
  3. huskybear Husqvarna
    B.C. Canada
    I pack them with dielectric grease and slip some heat-shrink tubing over them,heat slightly with a heat gun and call it done!
  4. dalecarlsbad Husqvarna
    SoCal
    2010 TE-250, 09 KTM XC-W, CRF-150
    Bonnie 904cc, 2 Daytona 675s.
    Grease & electrical tape should be fine.....I use these plastic caps (Home Depot) just because.......I have them laying around.
    Tinken and KXcam22 like this.
  5. KXcam22 Husqvarna
    That look really really good. Cam.
  6. Tinken Husqvarna
    Hesperia, CA
    MY12 WR511
    Yamaha
    I use large heat shrink tubing, push the connector through half way, then fold one side back. Pinch and zipty the tubing on the wire area tightly, then heat to shrink.
