seat cover install.
Discussion in 'Vintage Restoration Projects' started by Matt Cummings, Sep 16, 2013.
  1. Matt Cummings Husqvarna
    1972 WR250 Mikkola
    1984 IT490, 2000 KTM 200
    I searched the forum and google and didn't get any good information on the best way to install a seat cover onto a metal seat pan.
    The original cover tore around the screws and lead to the failure of the cover itself.
    Anybody got a better way? I normally use 1000 staples to hold the cover on and spread the load. I was told my stapler won't penetrate the metal pan.
    If I have to go screws does anybody know of a way to staple/rivet/attach a metal washer to absorb some of the load and resist tearing again?
    I have done a dozen seats on plastic but never metal. The seat was factory held on by flat head sheet metal screws but they were junk and destroyed, besides I hate anything flat head.
  2. visiteur1948 Husqvarna
    france Europe
    husqvarna only
    STICK NEOPRENE
    no problem !
  3. visiteur1948 Husqvarna
    france Europe
    husqvarna only
    for yor seat this part is
    original HVA !
    ( x 6 ! ):)
  4. Matt Cummings Husqvarna
    1972 WR250 Mikkola
    What's that?
    Anybody else got anything...
  5. 86 400 XC Husqvarna
    Calgary
    75,82,83,2x84,85,3x86,87,88 and 89
    more Huskys
    Sand the metal clean.
    Contact cement both surfaces and let dry before sticking.
    Add a screw here and there after, is all you can do.
  6. jo360 Husqvarna
    perth australia
    1983 exc framed wr430 engine
    ktm 520exc
    pop rivets and washers or as above industrial strength bonding agent.
  7. stormer254 Husqvarna
    England
    More than I dare let her know
    Yes!
    If there is a lip round the seat use car upholstery clips to hold it on, then use glue and self tapping sheet metal screws to finish. The screws will rust and rot the cover evenyually just like staples on a plastic base:( .
  8. dartyppyt Husqvarna
    Illinois
    17 TE 150, 82CR 500
    Contact cement, use soldering iron to make holes in vinyl, drill, use aluminum pop rivets with aluminum washers.
  9. visiteur1948 Husqvarna
    france Europe
    husqvarna only
    original system
    HUSQVARNA
    for a cover seat !:rolleyes:
  10. dumpbear Husqvarna
    Shepherd mi.
    360wr burl rep/74works bike/76360wr
    goldwing
    Visiteur has the right idea i made mine at work out of s/s pop riveted them on with contact cement worked great i had my wife help me with the second one i did 4 hands are better than 2 and i didn't hardly even yell at her!:lol:
  11. 84scrambler Husqvarna
    mid Florida
    I am having this same issue on my 79 but my pan is a lil rusty , so I am going to look and see if someone makes a plastic one ?
  12. wrx Husqvarna
    845 newyork
    1973 to 1986 husky's various models
    RM -250 / Buell / Penton 400 mc5
    3M upholstery adhesive ,alot of wooden /spring style clothes pins and a whole lot of patience.
  13. Crashaholic Husqvarna
    Antelope Valley, CA.
    73 450WR 6spd motor in a 75 MK frame
    Contact adhesive and a clean surface works well for me. I've never had to use fasteners. Shouldn't have to use clamps either but they certainly wouldn't hurt if the cement isn't setup enough before assembly. I know that high temps, e.g. greater than 100 degrees, can make the cement soft even though its dry to the touch (and before curing 100%). This will allow the seat cover to creep across the pan over a 2 - 3 hour period leaving you with a big let down when you return later to check out your handy work.
  14. disonny Husqvarna
    upstate ny
    73 360 wr/rt, 75 wr250 78 cr250,
    83 wr250, 84 wr400
    There are small tabs on mine, pointed so they go thru the cover and bend them to hold it. Along with the glue it should be good. also, heat the seat cover with a hair drier to stretch the cover. When it cools it will shrink a little and make a nice fit
