Seeking horsepower for my SM610
Discussion in '610/630' started by nsrrider, Sep 3, 2009.
  1. nsrrider Husqvarna
    Prineville, OR
    2017 FE450
    Yamaha FJ09, Triumph Tiger Cub
    Thought I'd post to see what anybody else is doing to up the output a little. I have a 08 SM610 that I love, but wish it had a few more HP, particularly in the higher third of the power band. It runs well and I've done the Leo slip-on and 02 sensor removal......it's just that the power is well, uninspiring. Last week I rode a buddy's KTM SM690.......while I'm not rushing out to get one, I did like the output of the bigger motor.
    I had a DR 650 that I slipped a higher comp piston into and really liked what it did for that bike.
    The Husky spins really slow on the elec starter and I'd be a little nervous about upping the comp.
    I recognize that there is RARELY an engine mod one can do to a stock motor and not suffer some kind of negative consequence but, I'm not seeing much in the way of anybody experimenting with pistons, cam etc.........
    any ideas????
  2. miketv Husqvarna
    Columbus, Ohio
    You might try contacting George at Uptite Husqvarna, his shop has been modding those motors for a long time.
  3. Motosportz CH Sponsor
    As you are in Portland i would suggest Russ Fletcher (Vancouver WA). He has 5 AMA engine builder titles to his name building huskys and husabergs. He knows his stuff. Big into head mods. Very high end guy and knows these motors well.
    http://www.motosportz.com/fletchtrick/fletchtrickhome.htm
  4. nsrrider Husqvarna
    Prineville, OR
    2017 FE450
    thanks.......I cant seem to find a number for russ fletcher's shop......
  5. Motosportz CH Sponsor
    try 360-513-7569
  6. nsrrider Husqvarna
    Prineville, OR
    2017 FE450
  7. mtne Husqvarna
    Denver
    08' TE610 + 08'TE610 sumo'd
    KTM 950SE
    And of course, please let us know what you find out...........
  8. jerbear610 Husqvarna
    Sacramento,CA
    14' WR300, 11' TE511, 06'TE610 sold
    11' Husaberg FE570, 15' Beta 300RR
    I pretty much ride offroad exclusively but I've got no complaints with the power
    output on my TE610 w/Leo Vince and JD Jetts. I lowered the gearing a bit and I
    can ride tight trails in second gear and let the torque of the mighty 610 chug along
    with the slight blip of the throttle. It is truly an amazingly versatile, powerful in all
    the right ways type motor. I've ridden a 2000 DR650 and I thought it had a nice roll-on
    powerband although in a drag race my 94' KLX650 (my previous bike) would win everytime.
    Since I've lowered the gearing every time I ride on pavement it's hard to keep the
    front wheel on the ground through the first four gears.
    What I've found over the years with the many bikes that I've owned is enough is never
    enough. No matter what mods you do you're always looking for more. I am more than
    happy with the power of my 610, it's the weight and size of the bike that is a little
    excessive for what I like. Being that you ride pavement I'd say give it some time to
    break in and you will see that it is a surprisingly powerfull,smooth motor. Jerry
  9. nsrrider Husqvarna
    Prineville, OR
    2017 FE450
    I ride a TE510 in the dirt and feel like its power output is totally adequate....if not more than I can use in the tight, technical woods that I like to ride in. The 610 is just a bit uninspiring in output for the street. In fact, I'm guessing the 510 is more powerfull than the 610. I cant see lowering the gearing on 610......its a great compromise between relaxed highway speeds and lower gear snap. I get the impression that this motor is mostly the same as it was in 2000 and while its a nice motor....its down on HP. I've just ordered a piston kit from Wiseco that will bump compression a tiny bit.....still suppose to run on pump gas. Will also have a quality job of lapping the valves done......will report back on the results, it may be a month or so before I get it done......
  10. nsrrider Husqvarna
    Prineville, OR
    2017 FE450
    Just in the mail!
