SEL 1 SEL2
Discussion in 'EFI/carb' started by Kreza, Jul 13, 2011.
  1. Kreza Husqvarna
    Ballarat, Australia
    2010 TE 450
    1998 KX80 2013 TM85
    G'day all, can someone please explain what SEL 1 and SEL 2 are when switching on the ignition?
    2010 TE450
  2. Ex HVUK Husqvarna
    England
    None
    SEL1 is full power, SEL 2 is 'soft' power. You switch between them by holding down the map switch on the bars for about 5 seconds once the engine is warmed up.
    Dave
  3. Kreza Husqvarna
    Ballarat, Australia
    2010 TE 450
    1998 KX80 2013 TM85
    Thanks for that, only there lies the problem, I don't have any other switches on the bars and I can't seem to find anything on the dash display after its started?????????
  4. Kreza Husqvarna
    Ballarat, Australia
    2010 TE 450
    1998 KX80 2013 TM85
    Unless I am meant to start the bike as Sel 2 appears before Sel 1????? Also forgot to mention that the O2 sensor and catalytic converter have been removed by dealer when bought new (is this the power up option)
  5. HUSKYnXJnWI Husqvarna
    Central Wisconsin, USA
    09TE450
    YOU need to buy and hook up the Dual Mode switch to switch from Sel1 and sel2 if that's something you want.
    I have it- cause I thought the bike should have all its "options" available and out of curiosity I got it early on when my 09 was new. I almost never use it. For me its more or less a novelty. This lets you use sel2- you are already in sel1 (which is full power). YOU can control the power with your throttle and clutch- easily enough-.
    Here's some previous posts on the subject:
    http://www.cafehusky.com/threads/an...ble-map-switch-on-te-250-310.2780/#post-40621
    http://www.cafehusky.com/threads/ca...1-and-sel2-with-stock-dash.17992/#post-156976
  6. Kreza Husqvarna
    Ballarat, Australia
    2010 TE 450
    1998 KX80 2013 TM85
    Cheers again, probably just stick to throttle and clutch as you say
