Service for linkage & swingarm
Discussion in 'Common Items on Husqvarnas: Tires/tubes/grips/etc' started by Swampds, Jan 19, 2009.
  1. Swampds Husqvarna
    Sarasota Florida
    I am about to do my service on my 07 TE 450. I remember robertaccio had a really good write up on doing his te. Do you happen to have that write up available here?
    I thought I remembered you having to lift the subframe....is this neccessary? If anybody else has a good write up that would be great.
    TIA
  2. Swampds Husqvarna
    Sarasota Florida
    Anybody?
    Coffee....is there any way to locate that thread on TT and post it here it would be a great help!
    TIA
  3. Coffee CH Owner
    That would be a huge no no. Definitely not a cool thing to do that is considered 'stealing content'. Anyone that has posted something on TT can post the same info here. Copying someone else's posts and pasting it on CH is not cool though - at least I'm not doing that and I'm not encouraging it.
    If it means anything I've kept a window open with this thread opened up so I would remember to get back to it... hang on...
  4. Coffee CH Owner
    Rear suspension maintenance on a 2006 TE250
    Remove brake from swing arm, note one is a sheet metal screw and another is a bolt
    Support brake
    Remove brake pedal
    Remove cover, kickstand, and roller from left side
    Pic says it all
    Glad I did the suspension that bolt was a bit dry
    All clean, bolt on left needs washer (not shown).
    There is a bushing with shoulder in swing arm, then washer, then nut all under the plastic covers
    These grease fittings are nice but not complete - I would not rely on the grease fittings greasing everything.
    Also the file "2006-DOHC-Husky-parts.pdf" is different than what this TE250 had. Here is a nice feature:
  5. Coffee CH Owner
    Did that help?
  6. Swampds Husqvarna
    Sarasota Florida
    Thanks Dean!! I didn't want to copy that info and post it here....I thought maybe I could get Roberts or your attention to post his write up here since it was pretty thorough.
  7. 5valves Husqvarna
    Gardner Kansas
    you should move that to tech section. jmho.
    good stuff
    thanks
  8. Coffee CH Owner
    Excellent idea :thumbsup:
    I just copied the one post into the tech ref section.
