125-200cc Service Manual for 09 Wr125
Discussion in '2 Stroke' started by dartyppyt, Mar 18, 2010.
  1. dartyppyt Husqvarna
    Illinois
    17 TE 150, 82CR 500
    Does anyone have the torque values for all the bolts on a 09 WR125 and also any pages showing the top end and power valve adjustment?
    The new manual doesn't have hardly anything in it:excuseme:. I had to print the manual for the 50mm forks from Marzocchi site.
    Thanx!
  2. dubbs Husqvarna
    Ontario
    I'm looking for one for my '06 WR 125 also. I had just found one for my 610 online but still need one for my 125.
  3. wallybean Mini-Sponsor
    Montana
    I have one for an 08 but it is not what you would expect from a true indepth service manual. I will see if I can copy and post all the torque specs because those will be the same.
    Walt
  4. wallybean Mini-Sponsor
    Montana
    Applicazione Filettatura
    Application Threading
    Application Filetate Nm Kgm Lb/ft
    Prigioniero fiss. testa cilindro
    Stud bolt fixing head and cylinder M8x1,25 (*) 19,6÷21,6 2,0÷2,2 14,5÷15,9
    Prisonnier de fixation cylindre
    Dado fiss. cilindro
    Nut fixing the cylinder M8x1,25 17,6÷19,6 1,8÷2,0 13,0÷14,5
    Ecrou de fixation cylidre
    Vite fiss. piastrina cuscinetto basamento
    Screw fixing base bearing plate M6x1 (*) 7,9÷8,7 0,81÷0,89 5,8÷6,4
    Vis de fixation plaque palier soubassement
    Prigioniero ant. fiss. cilindro
    Front stud bolt fixing cylinder M8x1,25 (*) 19,6÷21,6 2,0÷2,2 14,5÷15,9
    Prisonnier avant de fixation cylindre
    Prigioniero post. fiss. cilindro
    Rear stud bolt fixing cylinder M8x1,25 (*) 19,6÷21,6 2,0÷2,2 14,5÷15,9
    Prisonnier arrière de fixation cylindre
    Vite fiss. piastrina cuscinetto albero primario
    Screw fixing main shaft bearing plate M5x0,8 5,1÷5,7 0,52÷0,58 3,8÷4,2
    Vis de fixation plaque palier arbre moteur
    Vite fiss. inserto albero motore
    Screw for fixing the main shaft insert M5x0,8 9.8 1 7.2
    Vis de fixation insert de l’arbre moteur
    Vite fiss. leva distribuzione
    Screw for fixing the timing system levers M5x0,8 5.9 0.6 4.3
    Vis de fixation leviers de la distribution
    (*): “LOCTITE 243”
    Dado fiss. mozzo frizione
    Nut fixing clutch hub M16x1 27,4÷30,4 2,8÷3,1 20,2÷22,4
    Vis de fixation moyeu embrayage
    Vite fiss. molla frizione
    Screw fixing clutch spring M6x1 7÷7,7 0,71÷0,79 5,1÷5,7
    Vis de fixation ressort embrayage
    Vite fiss. leva avviamento
    Screw fixing starter lever M6x1 8,8÷9,8 0,9÷1,0 6,5÷7,2
    Vis de fixation levier de démarrage
    Vite fiss. perno avviamento
    Screw for fixing the start pin M6x1 9.8 1 7.2
    Vis de fixation goujon de démarrage
    Vite fiss. rocchetto com. cambio
    Screw fixing gearbox sproket M5x0,8 (**) 5,1÷5,7 0,52÷0,58 3,8÷4,2
    Vis de fixation couronne de commande boite des vitesses
    Vite fiss. bussola com. cambio
    Screw fixing gearbox bush M6x1 (*) 8,8÷9,8 0,9÷1,0 6,5÷7,2
    Vis de fixation douille de commande boite des vitesses
    Vite fiss. leva cambio
    Screw fixing gearbox lever M6x1 8,8÷9,8 0,9÷1,0 6,5÷7,2
    Vis de fixation levier boite des vitesses
    Dado fiss. pignone pompa acqua
    Nut fixing water pump pinon M12x1 46,6÷51,4 4,8÷5,2 34,6÷37,6
    Ecrou de fixation pignon pumpe à eau
    Vite fiss. superiore telaio posteriore
    Nut fixing upper rear frame M8x1,25 24,5÷26,5 2,5÷2,7 18,1÷19,5
    Ecrou de fixation supérieur cadre arrière
    Vite fiss. inferiore telaio posteriore
    Nut fixing lower rear frame M8x1,25 24,5÷26,5 2,5÷2,7 18,1÷19,5
    Ecrou de fixation inférieure cadre arrière
    Vite fiss. rullo catena
    Nut fixing chain roller M8x1,25 25,5÷28,5 2,6÷2,9 18,8÷21
    Ecrou de fixation rouleau chaíne
    Vite fiss. anteriore motore
    Nut fixing engine front M8x1,25 33,3÷37,3 3,4÷3,8 24,5÷27,5
    Ecrou de fixation avant moteur
    Vite fiss. inferiore motore
    Nut fixing engine low side M8x1,25 33,3÷37,3 3,4÷3,8 24,5÷27,5
    Ecrou de fixation inférieur moteur
    Vite rotazione cavalletto laterale (WR)
    Screw for rotation of side stand (WR) M8x1,25 () 11,7÷11,9
    1,19÷1,21 8,60÷8,75
    Vis de rotation béquille latérale (WR)
    Vite fiss. piastra attacco sup. motore al telaio
    Screw for fixing the plate for upper connection to the frame M8x1,25 24,5÷26,5 2,5÷2,7 18,1÷19,5
    (*) “LOCTITE 243” (**) “LOCTITE 270” () “LOCTITE 242”
    Vite fiss. superiore motore
    Screw fixing engine upper side M8x1,25 24,5÷26,5 2,5÷2,7 18,1÷19,5
    Vis de fixation supérieure moteur
    Vite fiss. cavallotto freno anteriore
    Screw fixing front brake connection M6x1 4,7÷5,1 0,48÷0,52 3,5÷3,8
    Vis de fixation crampillon frein avant
    Vite fiss. tubazione freno ant. sulla pompa freno 18,1÷20,1 1,85÷2,05 13,4÷14,8
    Screw for fixing the front brake pipes on brake pump M10x1
    Vis de fixation tuyauterie frein avant sur la pompe frein 23,5÷25,5 2,4÷2,6 17,3÷18,8
    Vite fiss. cavallotto frizione
    Screw fixing clutch connec tion M6x1 4,7÷5,1 0,48÷0,52 3,5÷3,8
    Vis de fixation crampillon embrayage
    Vite fiss. pedale freno posteriore
    Screw fixing rear brake pedal M10x1,25 (*) 39÷44 4,0÷4,5 29÷32,5
    Vis de fixation pédale frein arrière
    Vite fiss. pompa freno posteriore
    Screw fixing rear brake pump M6x1 9,8÷10,8 1,0÷1,1 7,2÷8,0
    Vis de fixation pompe frein arrière
    Vite fiss. serbatoio fluido freno
    Screw fixing brake fluid tank M6x1 2,35÷2,55 0,24÷0,26 1,73÷1,88
    Vis de fixation reservoirs fluide des freins
    Vite fiss. tubazione freno posteriore
    Screw fixing rear brake pipe M10x1 18,1÷20,1 1,85÷2,05 13,4÷14,8
    Vis de fixation tuyauterie frein arrière
    Interruttore stop posteriore (WR)
    Rear light switch (WR) M10x1 13,8÷15,7 1,4÷1,6 10,1÷11,6
    Interrupteur feux de stop (WR)
    Vite fiss. perno ruota anteriore
    Screw fixing front wheel axle M10x1,5 49÷55 5,0÷5,5 36,2÷39,8
    Vis de fixation pivot roue avant
    Vite fiss. steli forcella
    Screw fixing forkrods M8x1,25 23,5÷25,5 2,4÷2,6 17,3÷18,8
    Vis de fixation tiges fourche
    Ghiera reg. cuscinetti sterzo (1° avvitamento)
    Ring nut for handlebar bearing adjustment (1st turn) M25x1 3,2÷3,6 0,33÷0,37 2,4÷2,7
    Collier de réglage paliers de direction (1ère vissage)
    Dado perno di sterzo
    Nut for handlebar pin M24x1 79÷87 8,1÷8,9 58÷64
    Ecrou pivot de direction
    Vite fiss. camma regolazione pedale freno
    Screw for fixing the brake pedal adjusting cam M6x1 18,1÷20,1 1,85÷2,05 13,4÷14,8 Vis de fixation came de réglage pédale du frein
    WR
    CR
    How's that for unreadable, :lol:
    Walt
  5. nimiz1 Husqvarna
    IL
  6. LawnDartMike Husqvarna
    Salem, OR USA
    Has anyone found a 2009 WR 125 service manual?
  7. utopia Husqvarna
    Jackson, WY
    WR250, WXC125
    Try calling Halls. I just got one for my WR250 from them.
  8. LawnDartMike Husqvarna
    Salem, OR USA
    Thanks Wallybean for the settings. I cleaned it up a bit. Now if I can just figure out what the Italian to English translated parts are...
    :cheers:
    WR 125 2009 Torque Settings
    Application / Bolt Size / Nm / Kgm / Lb/ft
    Stud bolt fixing head and cylinder / M8x1.25 (*) / 19.6-21.6 / 2.0-2.2 / 14.5-15.9
    Nut fixing the cylinder / M8x1.25 / 17.6-19.6 / 1.8-2.0 / 13.0-14.5
    Screw fixing base bearing plate / M6x1 (*) / 7.9-8.7 / 0.81-0.89 / 5.8-6.4
    Front stud bolt fixing cylinder / M8x1.25 (*) / 19.6-21.6 / 2.0-2.2 / 14.5-15.9
    Rear stud bolt fixing cylinder / M8x1.25 (*) / 19.6-21.6 / 2.0-2.2 / 14.5-15.9
    Screw fixing main shaft bearing plate / M5x0.8 / 5.1-5.7 / 0.52-0.58 / 3.8-4.2
    Screw for fixing the main shaft insert / M5x0.8 / 9.8 / 1 / 7.2
    Screw for fixing the timing system levers / M5x0.8 / 5.9 / 0.6 / 4.3
    Nut fixing clutch hub / M16x1 / 27.4-30.4 / 2.8-3.1 / 20.2-22.4
    Screw fixing clutch spring / M6x1 / 7-7.7 / 0.71-0.79 / 5.1-5.7
    Screw fixing starter lever / M6x1 / 8.8-9.8 / 0.9-1.0 / 6.5-7.2
    Screw for fixing the start pin / M6x1 / 9.8 / 1 / 7.2
    Screw fixing gearbox sprocket / M5x0.8 (**) / 5.1-5.7 / 0.52-0.58 / 3.8-4.2
    Screw fixing gearbox bush / M6x1 (*) / 8.8-9.8 / 0.9-1.0 / 6.5-7.2
    Screw fixing gearbox lever / M6x1 / 8.8-9.8 / 0.9-1.0 / 6.5-7.2 /
    Nut fixing water pump pinion / M12x1 / 46.6-51.4 / 4.8-5.2 / 34.6-37.6
    Nut fixing upper rear frame / M8x1.25 / 24.5-26.5 / 2.5-2.7 / 18.1-19.5
    Nut fixing lower rear frame / M8x1.25 / 24.5-26.5 / 2.5-2.7 / 18.1-19.5
    Nut fixing chain roller / M8x1.25 / 25.5-28.5 / 2.6-2.9 / / 18.8-21
    Nut fixing engine front / M8x1.25 / 33.3-37.3 / 3.4-3.8 / 24.5-27.5
    Nut fixing engine low side / M8x1.25 / 33.3-37.3 / 3.4-3.8 / 24.5-27.5
    Screw for rotation of side stand (WR) / M8x1.25 (***) / 11.7-11.9 / 1.19-1.21 / 8.60-8.75
    Screw for fixing the plate for upper connection to the frame / M8x1.25 / 24.5-26.5 / 2.5-2.7 / 18.1-19.5
    Screw fixing engine upper side / M8x1.25 / 24.5-26.5 / 2.5-2.7 / 18.1-19.5
    Screw fixing front brake connection / M6x1 / 4.7-5.1 / 0.48-0.52 / 3.5-3.8
    Screw for fixing the front brake pipes on brake pump / M10x1 / 23.5-25.5 / 2.4-2.6 / 17.3-18.8
    Screw fixing clutch connection / M6x1 / 4.7-5.1 / 0.48-0.52 / 3.5-3.8
    Screw fixing rear brake pedal / M10x1.25 (*) / 39-44 / 4.0-4.5 / 29-32.5
    Screw fixing rear brake pump / M6x1 / 9.8-10.8 / 1.0-1.1 / / 7.2-8.0
    Screw fixing brake fluid tank / M6x1 / 2.35-2.55 / 0.24-0.26 / 1.73-1.88
    Screw fixing rear brake pipe / M10x1 / 18.1-20.1 / 1.85-2.05 / 13.4-14.8
    Rear light switch (WR) / M10x1 / 13.8-15.7 / 1.4-1.6 10. / 1-11.6
    Screw fixing front wheel axle / M10x1.5 / 49-55 / 5.0-5.5 / 36.2-39.8
    Screw fixing fork rods / M8x1.25 / / 23.5-25.5 / 2.4-2.6 / 17.3-18.8
    Ring nut for handlebar bearing adjustment (1st turn) / M25x1 / 3.2-3.6 / 0.33-0.37 / 2.4-2.7
    Nut for handlebar pin / M24x1 / 79-87 / 8.1-8.9 / 58-64
    Screw for fixing the brake pedal adjusting cam / M6x1 / 18.1-20.1 / 1.85-2.05 / 13.4-14.8
    (*) LOCTITE 243
    (**) LOCTITE 270
    (***) LOCTITE 242
    ripnriding likes this.
  9. LawnDartMike Husqvarna
    Salem, OR USA
    I also found this:
    NOTE - If not otherwise specified, standard tightening torques for the following thread:
    M5x0.8 / 4.9-6.9 / 0.5-0.7 / 3.6-5
    M6x1 / 8.8-9.8 / 0.9-1 / 6.5-7.2
    M8x1.25 / 21.6-23.3 / 2.2-2.4 / 16-17.3
  10. pahusky Husqvarna
    Hummelstown, Pa
    '14 TC250
    '12 250XC '09 1200GSA KLR650
    While I appreciate the effort, What Gives?? :excuseme:
    How can there not be a full service manual that comes with the bike?
    Or that is at least available to buy?
    It almost becomes a safety issue to not have the correct specs/torque.
    I'm trying to race prep a bike to put my son on and it does not make me all warm and fuzzy to be guessing at the setup torques. :shocked:
    Do you think the one for the '08 would be acceptable, at least for torque specs?
    Has anybody had any luck through the dealers or directly with Husky?
  11. speedkills Husqvarna
    Vancouver, WA
    2009 CR125
    CR500AF
    Just used these for putting my 144 kit on. Thanks for the assist Wally and Mike!
  12. razornpc Husqvarna
    iowa
    this is my biggest gripe about the husky. my ktm and kawasaki manuals were far superiour as far as detail and ease of desifering.
    what bolts and nuts are you looking for in particular? if you tell us id be happy to look in my 06 manual and let you know what i find.
