250-500cc settings carburation wr 360 1994
Discussion in '2 Stroke' started by ronin williams, Apr 21, 2009.
  1. ronin williams Husqvarna
    Spain
    wr 360 1994
    cr 250 1989 gas gas 300 2011
    hello anyone know the factory settings of the carburetor mikuni 38 or dellorto 37 i have two carburators and dont know jettings ,needles thanks
  2. JesPres Husqvarna
    Everett
    1994 wxc360
    1983 Yamaha DT100
    I got this info from HUSQVARNA WXC-WXE 250-360/94 USA PARTS CATALOG PG 124
    HI SPEED JET = 450
    LO SPEED JET = 40
    THROTTLE PISTON = 3.5
    METERING PIN 6AEJ-64
    METERING PIN POSITION = 5
    IDLE MIX ADJ SCREW 1e 1/2
    hope it helps!
  3. ohmygewd Husqvarna
    Melbourne, Australia
    Aprilia RSV1000
    Toss the Dellorto in the lake, bin, under a steam roller etc and do the same with the TM carb as well!!!
    Do yourself a favour and sort out a Keihin PWK 38 from a KTM300/250 or the Mikuni TMX from WR250.
    Why? The Dellorto is hard to jet meaning that it is very sensitive compared to the Keihin or even the TMX. The TM is the older design and parts availability is more of the issue however, the TM is probably a more economical carb than the TMX.
    The Lectron is suppose to the the go with all things carburetted but whatever you choice, don't stay with the Dellorto..it will just bring pain and misery
  4. 2premo Husqvarna
    Northern NV
    Sherco 300, 2002 KTM 380EXC
    the 94 TM carbs work fine, the later ones are problematic
    but yes if you don't mind a major investment the Lectron is VERY nice
    ohmygewd likes this.
  5. 2premo Husqvarna
    Northern NV
    what altitude and temp were you setting your baseline on
  6. rancher1 Husqvarna
    WA
    Wow, that reply was to a post from 2009, he probably has it sorted by now.
    2premo likes this.
  7. 2premo Husqvarna
    Northern NV
    wow, hahahahaha, good eye
    if he doesn't by now, he probably never will
  8. ohmygewd Husqvarna
    Aprilia RSV1000
    LoL...just noticed it...what year is it:doh:
    2premo likes this.
  9. JesPres Husqvarna
    Everett
    1994 wxc360
    1983 Yamaha DT100
    Yeah...i was posting for posterity in case other people coming in to the forum was asking the same question.
  10. rancher1 Husqvarna
    WA
    I just looked at those numbers again and I think the metering pin is missing a digit after the J.
  11. JesPres Husqvarna
    Everett
    1994 wxc360
    1983 Yamaha DT100
    snapshot of the info I posted
