Shock Mount Post
Discussion in 'Vintage/Left Kickers' started by motojason, May 4, 2016.
  1. motojason Husqvarna
    Erie, CO
    1987 430 CR, 83 250 CR, 82 430 XC
    KX500, KX250, KX125, FE570, TMEN 300
    I have a bolt stuck in the shock post on my 83 CR. Broke the easy-out off in the bolt too, so need to remove post. I removed the rear bolt, heated the post and tapped on it with a punch, but no movement. Are the mounts pressed into the frame, or is mine just frozen from rust, age, etc?
  2. stormer254 Husqvarna
    England
    More than I dare let her know
    Yes!
    Not that it helps, but I broke the bolt as well and having already broken my small easy out drilled the bolt out with a 5mm drill and ran a 6mm tap up and the new bolt holds fine albeit I used a bit of Loctite!
  3. motojason Husqvarna
    Erie, CO
    I was tyrying to get the post out to put it in the drill press and do the same. The broken easy out is so hard I was having difficulty drilling into it by hand.
  4. motomwo Husqvarna
    Imbler Oregon
    Many vintage big bore and automatics
    Yes they have a light press fit in the frame. They are probably rusted in, use something like PB blaster and possibly heat to make it easier to press them out. Also when installing a new post apply some anti seize compound.
    Marty
  5. motojason Husqvarna
    Erie, CO
    Marty, Thanks! Do you know if it will it come out from either direction? Can I press it in from the outside, toward the center?
  6. motomwo Husqvarna
    Imbler Oregon
    Yes, you can press them out in either direction.
    Marty
    justintendo likes this.
