Shock specs for 1980 frame
Discussion in 'Vintage/Left Kickers' started by Murph, Nov 27, 2010.
  1. Murph Husqvarna
    UK
    I need to replace the shocks on the 390 I am rebuilding. The frame is from a 1980 XC390 and I am trying to find out the specs of the shocks that should be fitted.
    I believe the overall length from eye to eye should be 17.25 inches but I also need to know the travel of the shock. Please could someone confirm both of these dimensions? Thanks in advance :)
  2. Ron Husqvarna
    Azusa, CA
    Murph,
    My 79 CR390 has 17-1/4" Ohlins (I believe they are original).
    The exposed shaft length is 4-1/4" and they have a 2" bumper.
    I would think this would be appropriate for your bike.
    Wasn't the 390 an "OR" in 79? I think the XC's didn't show up until 81.
    Hope this helps,
    Ron
  3. Murph Husqvarna
    UK
    Thanks Ron. As it happens I have just been looking at the Vintage Husky website and it has a copy of the brochure for the 1980 OR390 and it is exactly the frame I have, so I think you are correct. I was told it is an XC frame but now I agree with you, it is an OR frame.
    I am pretty sure the shocks on your bike will be the same ones used on the 1980 OR frame, so thank you for your help. Just one question. Is the 4-1/4 inch exposed shaft measured to the top of the bumper or is it not including the bumper at all? Thanks again.
  4. Ron Husqvarna
    Azusa, CA
    The 4-1/4" did not include the 2" bumper, so the shaft would be 6-1/4"
    with no bumper.
    I believe most tracks consider 1/2 of the bumper thickness, as shock travel.
    I agree the 80 frame is the same as the 79, except they cut the rear fender loop off on the CR's from 79 on.
    Ron
  5. patgas Husqvarna
    dolgellau/ wales
    yep sounds good
    i have 440mm ohlins wich is about 17.32 which is what your at murph 17.25 this is correct for you 79/80 frame
  6. Murph Husqvarna
    UK
    Thanks for the help guys, I now know what I need.
  7. ruwfo Administrator
    NJ
    1985 250XC, 2016 FJ-09
    Murph,
    My 1980 390CR has 16-1/2" c-c to shocks, & the Husky OR brochure
    i've attached says travel is 314mm or 12.4 ".
    Husky John
  8. ruwfo Administrator
    NJ
    Here's brochure
  9. Ron Husqvarna
    Azusa, CA
    I think and I could be wrong, the OR's used Curnutt shocks that were shorter to rake out the front end a bit more.
    The OR's got their changes based on input from the desert and Baja racers, like Larry Roeseler (I remember reading that somewhere).
    Ron
