Shock spring change out
Discussion in 'Common Items on Husqvarnas: Tires/tubes/grips/etc' started by Nesbocaj, Aug 18, 2009.
  1. Nesbocaj Husqvarna
    Thanks Kelly!!!:thumbsup:
    I have some new springs for the TE, the forks are easy enough, BUT
    changing out the rear spring......
    I do not have a spring compressor, will a couple of cinch straps work?
  2. Motosportz CH Sponsor
    No problem.
    No it is REAL EZ. spin the preload collars until they are clear to the top, lift the spring up a little and pull the lower cup with a slot out and slide the spring off. It is super EZ.
  3. Nesbocaj Husqvarna
    Sounds Easy-Peasy, thanks!
  4. Nesbocaj Husqvarna
    What a royal PIA to get the shock off of the bike, damn!:censored:
    Got 'er done.
