I am struggling to find definitive answers on who sells 2 or 3 finger levers for an 09 TE610. I am not looking for comments on the merits or demerits of short levers but first hand knowledge (and pics if possible) of members who have bought and fitted either just levers or complete new controls. Make and model numbers preferably. Thanks.
I use a 2 finger clutch lever.... I end up pinching my two little fingers between the lever and the grip if they are not shortys... I don't think this is the answer you are looking for, but I just cut the stockers short, and grind the end nice and smooth...
After contacting Magura several times, I was able to get a matching pair of shorter levers for my 630 and replacing the hand brake reservoir with a lower metal one similar to the right hand clutch (I didn´t like the way the plastic hand brake reservoir was mounted). I´d have to look up the part numbers. The problem was to get levers that activated the clutch and the brake light switches. There´s nothing fancy about the levers ... just standard but shorter. I couldn´t find any one who made shorter, anodized adjustable levers that fit and also activated the electric switches.
Pazzo and ASV. I don't have either, but have looked into them and they both work. Pazzo is big $$$, but can make a custom lever for any application. ASV makes a shorty, but you need the perch too. I haven't made up my mind, but will most likely get the ASV. Good luck Dom!
http://www.arclevers.com/ These guys do levers and are a block or two from Uptite Husqvarna in Santa Ana, CA. George gets some made up that have the Husky crown and his Uptite lasered on, in black or red for clutch or brakes. Not sure about short ones.
some pictures here '08 TE610 with ASV short levers http://tw.myblog.yahoo.com/jw!cHxrK...rticle?mid=4642&prev=4852&next=4603&l=f&fid=5
My bike- 09TE450 uses a Magura Clutch and a Brembo Front Brake- KTM used the same set up so it made those levers more common- should be stuff available (ktm uses the same brake mini switch on bikes that have brake lights (exc))... Personally, I bought a Magura Short Clutch lever (actually sold by Magura for their clutches) and I cut/filed my brake lever - I use handguards so I don't worry about not having the knob....
Seems like ARC are the ones that refer specifically to Husky options = how do the 630 levers differ to the 610?
I have Pazzo shorty's on my SM 610. Love 'em! Have 'em on my ST3 too! I got the ones for my Triumph at Duncanmoto & the shorty's were on the 610 when I bought it, but I think they came from Fast By Ferracci in Phil. Pa. Hope this helps.
No joy! Not generic for the 630 (as far as I can make out).The first set that I got from Magura didn´t match up with the switches ... and the short Maguras that I ecventually got are certainly not as nice as some others I´ve seen.
Hydraulic clutch on the 630? Run a search in supermotojunkie, there are few threads about short levers for the 610 on that site
That seems to be the general outlook with all the really nice levers. The short ones I got from Magura are certainly nothing special.
