Shortening clutch throw
Discussion in '4 Stroke' started by BigShooter, Aug 16, 2016.
  1. BigShooter Husqvarna
    te250
    Is there any way of shortening the throw on the hydraulic clutch of a TE250?
  2. ghte Husqvarna
    Bright, Victoria Australia
    There is a threaded knob/screw behind the lever this will wind the lever in or out to suit hand sizing
  3. BigShooter Husqvarna
    te250
    Yes, thank you. But I'm wondering about shortening the distance of lever travel to disengage the clutch its self. I have the lever moved out till it is almost kissing the shield of my bark buster to fit my grip reach; but, I'd like to shorten the pull. I thought perhaps the piston in the actuator cylinder and/or master cylinder might could be changed/modified, or something like that. I had a hand injury that effects the angle my ring and pinky fingers bend, and it plays hell with levers hitting my ring finger's central knuckle. I'm also fixing to trim down the lever to two finger length, unless a "shorty" lever is available.
  4. AndrewS Husqvarna
    Niagara Region, Ontario, Canada
    2015 FE350s 2013 TE310R
    2009 TE250 (sold)
    Interesting... The Midwest Mountain Engineering lever is a shorty, but also lighter pull which means longer travel. This is accomplished through a different pivot point.
    So, as much as I love my MME lever, I wouldn't recommend it for you.
  5. juicypips Husqvarna
    gloucestershire
    wr 360. 2002
    Is there no adjustment on the clutch itself?
  6. ghte Husqvarna
    I believe you can purchase a few other brands that have different throw lengths-not necessarily Husky specific. Not sure if there is a separate internals kit for your mode;l clutch however.
  7. Flash319 Husqvarna
    TC510
    KTM640 Supermoto
    The only way to change the throw distance is to change the pivot point. The throw will be shorter but will take more force. You dont get something for nothing.
  8. juicypips Husqvarna
    gloucestershire
    wr 360. 2002
  9. racemx904 Husqvarna
    owenton, ky
    2014 Beta 350RR & 1986 430XC
    Thought the TE was Cable?
  10. juicypips Husqvarna
    gloucestershire
    wr 360. 2002
    No something for nothing ;) =air
