250-500cc Should have knocked on wood
Discussion in '2 Stroke' started by lankydoug, Nov 11, 2015.
  1. lankydoug Husqvarna
    MO
    WR
    TM 300en
    Last week I was saying that my WR250 had 300+ hours on it the very next ride I noticed having to use the clutch more often like if riding a 125 also it kicked over easily, not like it's old self which would make you whimper if you weren't wearing good boots. I took it apart today and the piston still looked excellent as did the cylinder but the rings were worn out. An .015 " end gap and little to no tension. Here are some pics
    I did not clean the combustion chamber I simply wiped it with a paper towel. The cyl.had no signs of wear and a perfect cross hatch. I'm replacing the piston just because it owes me nothing and it's showing slight signs of wear on the intake side image.jpg image.jpg image.jpg
  2. Rob578 Husqvarna
    Atlanta GA was CA
    Beta 300RR Beta 500RS TE 630
    Honda 919 sold FJR1300 sold
    These are good solid motors.
    steadydirt likes this.
  3. shawbagga Husqvarna
    Eaton, Western Australia
    None
    2018 Gasgas XC250
    Reading the title of post I thought you'd had a catastrophic failure Doug! That's a good run outta that piston. Stick a wossner forged one in there n it'll be good for another 500+ hours!:)
  4. banana944 Husqvarna
    Central MA
    2009 SMR510, 1996 WXC360
    01 YZ300,01 KDX200 both street legal
    Can't ask for anything better than that.
  5. ohmygewd Husqvarna
    Melbourne, Australia
    Aprilia RSV1000
    Doug you ride it like a girly....where's the signs of 4 corner seizures or heaps of carbon crud on the top of the piston!!! No good mate, giving 2 stroke riders a bad name esp Husqvarna riders, showing us a 300hr bore a piston with very little wear:naughty:.........:D
    wayneoXCF, steadydirt and lankydoug like this.
  6. lankydoug Husqvarna
    MO
    WR
    TM 300en
    Ya I guess I could have at least turned it into an Amsoil/VP110 fuel infomercial. Truth is I ride like an old man because I am an old man but I still keep up with some of the youngsters in the technical stuff.
  7. shawbagga Husqvarna
    None
    2018 Gasgas XC250
    Just made me laugh with the first post you sounded disappointed with 300 hours :)
  8. juicypips Husqvarna
    gloucestershire
    wr 360. 2002
    300 hours aint bad, and the lack of four corner seizures is why its gotten to 300 not 3!
    Jettings spot on by all accounts so thats the carbon build up idea ruined.
    Those are good looking components for them hours, your right about piston ive seen them shatter just where the lower mark is on the intake.
    You did measure across there too see if its still in spec? The bore below intake not piston.
  9. lankydoug Husqvarna
    MO
    WR
    TM 300en
    Ok, I got it put back together and it is back to it's old self. I didn't miss the mid-range power until it was gone and now that it's back Woo-hooo! :banana: The Wr250 really has a solid and fast engine, it's true that it's a bit heavy but for the dependability and power is worth it.
    I ordered a piston from Halls at the beginning of the week and probably would have had it by Friday except for a mix up I caught when they emailed me my receipt... they had me down for a 300 piston which also explained the sticker shock (the 250 piston is about $40 cheaper). It's all good now and thanks to Halls for stocking parts for our Huskys, they are much better than my local YamaKawaHonda dealer.
  10. Huskynoobee CH Sponsor ZipTy Racing
    Castaic, CA
    2011 TE449 2006 WR250
    What piston did you get? I'm thinking I might freshen the top end too. Did you experience any low rpm lug noise before the rebuild? Like a piston slap /knock?
  11. lankydoug Husqvarna
    MO
    WR
    TM 300en
    I ordered the stock factory piston, my cylinder was stamped "C" so I ordered the "C" piston. I didn't have any noises and actually I could have just bought rings because the piston wear was minimal but rings would have probably only got me another 100 hours and I didn't want to risk a blow up. For a factory piston, rings pin & bearing, head "O" rings and a base gasket it was $272.00 which still seems high compared to a Weisco kit for my yz125 @ $150 with gaskets but I guess I could have saved some money by going with a Vertex in the Husky. The reason I went with factory was that I'm hoping to get another 300+ hours out of this one.
  12. Huskynoobee CH Sponsor ZipTy Racing
    Castaic, CA
    That's not bad. Glad to know I have option of the factory piston still. I think I'll tear it down and have a look after this weekend.
  13. shawbagga Husqvarna
    None
    2018 Gasgas XC250
    Vertex is oem isn't it?
  14. Motosportz CH Sponsor
    Amsoil rules, proved itself to me many times
  15. rancher1 Husqvarna
    WA
    Some years Vertex was stock. The Italians liked to use several suppliers over the years. Some models would actually have 3 different piston brand options. The vertex are good pistons.
    shawbagga likes this.
  16. shawbagga Husqvarna
    None
    2018 Gasgas XC250
    Yeh my 300 was vertex
  17. Miezie666 Husqvarna
    Germany
    2x YZ 125, 1x YZ250 2005, XT600 2KF
    on the 1999- wr250 you could also use a 1998 Suzuki RM 250 or a 1997-01 Honda CR 250 Piston instead.
  18. Huskynoobee CH Sponsor ZipTy Racing
    Castaic, CA
    Yeah, the wiseco pistons are listed for Honda cr250 as well.
  19. lankydoug Husqvarna
    MO
    WR
    TM 300en
  20. Miezie666 Husqvarna
    Germany
    i dont know why they didnt show up a b c d pistons- but its like i said- there are some pistons you can just drop in our 250 WRs.
