Should Headlight Be On Before Starting?
Discussion in 'TR650' started by TE250Guy, Feb 25, 2013.
  1. TE250Guy Husqvarna
    Washington
    2008 TE250, 2013 TR650 Terra
    2009 KLR 650, Yamaha XT 225
    There are two light bulbs in the Terra and also my '08 TE 250.
    On my 2008 Husky TE 250, when the key is on, before starting the engine, only the small light is ON.
    On my '13 Husky TR 650 Terra, both lights go on when the key is on, before starting the engine.
    I thought that was a slick feature on the TE 250 because it reduced the battery drain prior to starting.
    Is this normal behavior for the Terra?
  2. nev.. Terrarist
    Greensborough, Australia
    '13 TR650 Terra
    '14 XT1200ZE
  3. Coffee CH Owner
    That is how my 2013 TR650 Terra works... which I am assuming is normal.
  4. TE250Guy Husqvarna
    Washington
    Thanks. Good to know all is OK.
    I wonder why the little light is there? Sure would be nice to have it work like the TE 250. It also has a kick starter, which the TR 650 does not, so consequenses of a run down battery in the middle of nowhere are not good. Some KLR guys have added a headlight OFF switch to help reduce the battery load when starting if need be. I might do this to soften my paranoia when I can't find a current bush to plug into in the wild.
  5. Coffee CH Owner
    My 2006 TE250 has a little light too, it is quite handy if the main bulb burns out while riding. I have been assuming that is the reason they are there.
    No... I would not want a less than perfect battery on my tr650... a lot of things rely on it.
  6. Gedge Husqvarna
    Southern Hampshire
    TR 650
    Morini Granpasso 1200
    On european bikes the small bulb is a legal requirement ( in the UK its commonly known as a sidelight although its official term is Position Lamp...it needs to be capable of operating if the Healdight faiils and also for certain conditions when parking ( on the terra thats operated from the ignition key...)
    UK bike currently have All Day Headlights as its an EU homologation legal requirement although the UK hasnt signed up to it so its a 'gentlemans agreement'
